Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2011
    Jan 2012
    4
    Default Help with solids...
    I am working on the attached file. I need to either subtract or surface trim the corners of the cylinder but when I try to do either some other surfaces that i did not select get trimmed. How do i solve this problem? 6.dwg
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    I'm not exactly sure what the part is supposed to look like, so I guessed. This may not be what you're looking for, but I used your existing geometry to create 2D top view of that part using the FLATSHOT command, then used PRESSPULL to extrude the hub, and then the "flange", which I believe is the easiest way to make that part.
    Here's a video demonstration. --> http://www.screencast.com/t/rkrbuhFOQ
    If you still need assistance trimming solids, we can certainly help with that as well, but the model you posted didn't actually contain any solids.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    I moved this to the AutoCAD 3D Modelling & Rendering forum.
    Like nestly stated, you have NO solids, just regions, surfaces and lines.
    What are the end results you want?
    Forum Newbie
    AutoCAD 2011
    Jan 2012
    4
    Thank you Nestly. That is exactly what I needed to do. I have not yet explored the FLATSHOT command, which may be why I was having trouble.
  5. #5
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Quote Originally Posted by iamstd2 View Post
    Actually, I only used the FLATSHOT command to get the geometry back to 2D. If I was starting from scratch and had the dimensions, I'd just have drawn it in 2D, then used EXTRUDE twice to make the part(s) into a solid.
  1. What do I do to turn wire framed solids into solids
    By cyter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Apr 2011, 11:09 pm
  2. solids help
    By xander3 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Nov 2008, 04:11 pm
  3. How to substract N number of solids from n number of solids using C# code
    By srikanthkamuju in forum AutoCAD Drawing Management & Output
    Last Post: 16th Oct 2008, 08:18 am
  4. Solids
    By mattwsp in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Aug 2006, 10:24 am
  5. importing solids into 3dsmax5 - solids coming out see thru?
    By ironman2 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2005, 05:21 am
