Results 1 to 6 of 6
    Senior Member alijahed's Avatar
    alijahed's Computer Details
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    Cape Town/South Africa
    386
    Default Drive an angular constraint
    Hi All,
    I want to drive an angular constraint. But, instead one part moves towards the other I want to have the motion of both moving towards each other at the same time. Is it possible?
    Cheers
    Ali
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    Attach your assembly here.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    386
    It sounds crazy but how can I attach files here!
    There is one for Image another one for video but there is noting for attaching other files!
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,106
    Select "Go Advanced" at lower right of reply box, then "Manage Attachments".
    Should be a nice selection.
  5. #5
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    386
    Assembly1.zip
    Thanks, please see the attached file.
  6. #6
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    Can you assemble with a workplane in the middle of the desired motion and then name the variable parameter for the angle constraint and then drive the parameter?
  1. Replies: 0
    Last Post: 10th Oct 2011, 07:30 am
  2. Drive constraint
    By Chriske in forum Autodesk Inventor
    Last Post: 8th Jul 2010, 01:46 pm
  3. Drive constraint between two gears.
    By arshavin23 in forum Autodesk Inventor
    Last Post: 19th May 2010, 04:00 pm
  4. C:\ drive versus D:\ drive
    By Coosbaylumber in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2009, 11:16 pm
