I'm pretty sure your lines didn't create closed area, because this is working code
To make sureyou better use closed polyline instead or draw lines chainage
dependend on previous line points, e.g.:
~'J'~Code:' by Tony Tanzillo Friend Function PolarPoint(basepoint As Point3d, angle As Double, distance As Double) As Point3d Return New Point3d(basepoint.X + (distance * Math.Cos(angle)), basepoint.Y + (distance * Math.Sin(angle)), basepoint.Z) End Function <CommandMethod("demoreg")> _ Public Sub RegionDemo() Dim acCurDb As Database = HostApplicationServices.WorkingDatabase Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor Try Using acTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = acCurDb.TransactionManager.StartTransaction() Dim acBlkTbl As Autodesk.AutoCAD.DatabaseServices.BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) Dim acBlkTblRec As Autodesk.AutoCAD.DatabaseServices.BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite) Dim acDBObjCol As DBObjectCollection = New DBObjectCollection() Dim Line1 As Line = DrawLine(New Point3d(0, 0, 0), 0.0, 100) Dim Line2 As Line = DrawLine(Line1.EndPoint, Math.PI / 2 - Math.PI / 6, 100) Dim Line3 As Line = DrawLine(Line2.EndPoint, Math.PI / 2 + Math.PI / 6, 100) Dim Line4 As Line = DrawLine(Line3.EndPoint, Math.PI, 100) Dim Line5 As Line = DrawLine(Line4.EndPoint, Math.PI * 1.5 - Math.PI / 6, 100) Dim Line6 As Line = DrawLine(Line5.EndPoint, Math.PI * 1.5 + Math.PI / 6, 100) acDBObjCol.Add(Line1) acDBObjCol.Add(Line2) acDBObjCol.Add(Line3) acDBObjCol.Add(Line4) acDBObjCol.Add(Line5) acDBObjCol.Add(Line6) ''MsgBox(Line1.EndPoint.X) Dim myRegionCol As DBObjectCollection = New DBObjectCollection() myRegionCol = Autodesk.AutoCAD.DatabaseServices.Region.CreateFromCurves(acDBObjCol) Dim acRegion As Autodesk.AutoCAD.DatabaseServices.Region = DirectCast(myRegionCol(0), Autodesk.AutoCAD.DatabaseServices.Region) acBlkTblRec.AppendEntity(acRegion) acTrans.AddNewlyCreatedDBObject(acRegion, True) ' ---> here you might be want to erase and dispose lines after acTrans.Commit() End Using Catch ex As System.Exception MsgBox("Error" + vbLf + ex.ToString) End Try End Sub
Good Day
