Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,372
    I just bought an HP Envy with very nice specs and it is running 2013 autocad and inventor very well. I don't work with large files so I don't know about performance on big files. it was $1250, so above your budget but you could lower some of the options.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  2. #12
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,133
    Quote Originally Posted by rkent View Post
    I am working on an HP as I write this, had another one before this.
    In my company we have had less than stellar luck with HP longevity.
    My latest laptop acquisition was a DELL XPS15 Z, which is pretty nice.
    HP just released their new IVY BRIDGE lineup, and they do look interesting.
  3. #13
    Senior Member paisis123's Avatar
    paisis123's Computer Details
    WIN 7 PRO
    Cyperpower CUSTOM
    Gigabyte GA-870A-UD3 (Socket M2)
    AMD Phenom II X6 1055T
    8.0GB Dual-Channel DDR3
    ATI Radeon HD 6870 x2 (CROSSFIRE MODE)
    977GB GRAID SCSI Disk Device (SCSI)
    3 TB external segate drive
    3x ViewSonic VA2231w-LED
    Mechanical
    paisis123's Discipline Details
    Designer - Thermoplastic Extrusions
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    Just keep in mind on the task that you are trying to accomplish.
    Heres a list of common tasks and the requirements
    1. Large Drawing files - You need a Fast HDD or an SSD to load them up faster and easier
    2. Manipulating Multiple drawings at once - You need a Fast CPU in order to handle all the calculations
    3. Rendering - You need a muti-thread CPU at a decent clock rate to have optimal performance
    4. 3D design - You need a good GPU that can handle the 3d manipulation and rendering
    5. Simple 2D sketches - A good amount of RAM and CPU power is all that is needed
    6. If your needs require more then one option of 1-6, then buy accordingly
    I Built my PC with 2 purposes. 1. a Gaming PC 2. A mobile workstation and media center.
    Once you build and acquire goal in mind, then you have something in which you wont be disapointed
  4. #14
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    Quote Originally Posted by JD Mather View Post
    I would not consider a laptop with less than 17 inch screen for CAD work.
    You can get a 17" with 8Gig RAM for around $800 that will be fine for AutoCAD.
    I Agree, the Best bang for your buck is 8 GB of RAM, though i find 16 over kill. and the 24 gbs i have at my job is surprisingly good enough....
  1. AutoCAD 2012 and AutoCAD LT 2012 Service Pack 1 Released
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 7th Sep 2011, 01:34 am
  2. Replies: 0
    Last Post: 1st Sep 2011, 04:20 am
  3. Replies: 0
    Last Post: 13th Aug 2011, 01:30 am
  4. AutoCAD 2010 less than US$1000 !!!
    By Dicksham in forum Software & Licensing
    Last Post: 24th Dec 2009, 08:44 pm
  5. laptop for AutoCAD - 1000£
    By tomasso in forum AutoCAD Drawing Management & Output
    Last Post: 1st Apr 2006, 05:05 pm
