Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
  1. #11
    Junior Member
    Architecture 2013
    Jul 2011
    10
    You're welcome.
    I did notice a couple of things that I missed when I posted the code.
    The first thing is to update this line:
    Code:
    (vl-cmdf "explode" (entlast) "")
    You shouldn't need the quote marks at the end of the line. Just delete them. Let me know if that doesn't work for you.
    The other thing you could do is add *error* to the local variables
    Code:
    (/ *error* CurLayer OffsetDist VlaObj sset num Ang Ptdist StartPt EndPt)
    Otherwise I hope that works for you.
  2. #12
    Super Member DANIEL's Avatar
    Mechanical
    DANIEL's Discipline Details
    Industrial
    Mechanical
    AutoCAD 2013
    May 2005
    Arlington Texas
    1,005
    might want to read up on the code posting guidlines jsowinski
    If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
    Luminous beings are we, not this crude matter.
  3. #13
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
  4. #14
    Junior Member
    Architecture 2013
    Jul 2011
    10
    Thanks for letting me know.
  5. #15
    Senior Member
    Manufacture
    BrianTFC's Discipline Details
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    158
    that worked the only thing i was wondering is can we explode the rectangle after it offsets?
  6. #16
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
    Quick one:
    Code:
    (defun c:MyOffset ( / ent obj )
        (if
            (setq *dist*
                (cond
                    (   (getdist
                            (strcat "\nSpecify Offset Distance"
                                (if *dist* (strcat " <" (rtos *dist*) ">: ") ": ")
                    (   *dist*   )
            (while
                (progn (setvar 'ERRNO 0) (setq ent (car (entsel "\nSelect LWPolyline: ")))
                    (cond
                        (   (= 7 (getvar 'ERRNO))
                            (princ "\nMissed, try again.")
                        (   (eq 'ENAME (type ent))
                            (cond
                                (   (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (cdr (assoc 8 (entget ent))))))))
                                    (princ "\nObject is on Locked Layer.")
                                (   (eq "LWPOLYLINE" (cdr (assoc 0 (entget ent))))
                                    (foreach obj (vlax-invoke (setq obj (vlax-ename->vla-object ent)) 'explode)
                                        (vla-offset obj *dist*)
                                    (vla-delete obj)
                                    t
                                (   (princ "\nObject is not an LWPolyline.")   )
    (vl-load-com) (princ)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  7. #17
    Senior Member
    Manufacture
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    158
    Thanks, Lee
  8. #18
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
    No worries, it should work for all LWPolylines, even those with Arc segments.
  9. #19
    Senior Member
    Manufacture
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    158
    I need some help, this routine was written by jsowinski i've added a a line to change the layer of rectangle and explode it but it leaves the original rectangle underneath the line new lines. i need the original rectangle to be exploded. any help would be appreciated.
    Code:
    (defun c:Offsetpline (/ *error* OffsetDist VlaObj sset num Ang Ptdist StartPt EndPt)
    (vl-load-com)
    (defun *error* (msg)
    ); _end defun
    (setq OffsetDist (getreal "\nEnter an offset distance: "))
    (while (setq VlaObj (vlax-ename->vla-object (car (entsel "Select a Rectangle: "))))
    (setq Startpt (vlax-curve-getPointAtParam VlaObj 1))
    (setq Ang (+ (angle (vlax-curve-getStartPoint VlaObj)(vlax-curve-getPointAtParam VlaObj 1))(* (/ pi 180) 90)))
    (setq PtDist (distance Startpt (vlax-curve-getPointAtParam VlaObj 2)))
    (vlax-put-property vlaobj 'layer "Router - Green-V groove")
    (vl-catch-all-apply 'vlax-invoke-method (list VlaObj 'explode))
    (if (equal (polar Startpt Ang PtDist)(vlax-curve-getPointAtParam VlaObj 2) 1.0)
    (vl-catch-all-apply 'vlax-invoke-method (list VlaObj 'Offset OffsetDist))
    (vl-catch-all-apply 'vlax-invoke-method (list VlaObj 'Offset (- OffsetDist)))
    ); _end if
    (setq VlaObj (vlax-ename->vla-object (entlast)))
    (vl-catch-all-apply 'vlax-put (list VlaObj 'Layer "Router - Blue - Cuts"))
    (vl-cmdf "explode" (entlast))
    (setq sset (ssget "_P"))
    (setq num -1)
    (repeat (sslength sset)
    (setq VlaObj (vlax-ename->vla-object (ssname sset (setq num (1+ num)))))
    (setq StartPt (polar (vlax-get VlaObj 'StartPoint)(vlax-get VlaObj 'Angle) OffsetDist))
    (vl-catch-all-apply 'vlax-put (list VlaObj 'StartPoint StartPt))
    (setq EndPt (polar (vlax-get VlaObj 'EndPoint)(- (vlax-get VlaObj 'Angle) pi) OffsetDist))
    (vl-catch-all-apply 'vlax-put (list VlaObj 'EndPoint EndPt))
    ); _end repeat
    ); _end while
    ); _end defun
  10. #20
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
  1. Trimming Lines within a rectangle
    By Sundar in forum .NET, ObjectARX & VBA
    Last Post: 20th Jan 2012, 05:19 am
  2. finding distance between offset lines
    By fisher22 in forum AutoCAD Beginners' Area
    Last Post: 6th Jul 2011, 06:40 pm
  3. automatic offset lines?
    By stephenward in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Jul 2009, 11:07 am
  4. offset 2 lines add dimensions and tag
    By gazzalp in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Dec 2008, 12:35 pm
  5. How to separate text into individual lines?
    By Chris333 in forum AutoCAD Beginners' Area
    Last Post: 29th Oct 2007, 01:14 pm
Tags for this Thread
