Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
  1. #21
    Senior Member
    Manufacture
    BrianTFC's Discipline Details
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    159
    Lee, I tried using the routine that you wrote but it didn't work some of the routines that i use it with, that's why i was using jsowinski routine.
  2. #22
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,459
    You should've said - what error do you receive?
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  3. #23
    Junior Member
    Architecture 2013
    Jul 2011
    10
    BrianTFC-
    One of the things that happens with using vla-explode is that it can make a copy from the original. I think that's what happened when you found lines on top of the selected rectangle. You can try and delete the rectangle by adding something like this.
    (vl-catch-all-apply 'vla-delete (list VlaObj))
    I placed it into your program. (see below)
    Code:
    (defun c:Offsetpline (/ *error* OffsetDist VlaObj sset num Ang Ptdist StartPt EndPt)
    (vl-load-com)
    (defun *error* (msg)
    ); _end defun
    (setq OffsetDist (getreal "\nEnter an offset distance: "))
    (while (setq VlaObj (vlax-ename->vla-object (car (entsel "Select a Rectangle: "))))
    (setq Startpt (vlax-curve-getPointAtParam VlaObj 1))
    (setq Ang (+ (angle (vlax-curve-getStartPoint VlaObj)(vlax-curve-getPointAtParam VlaObj 1))(* (/ pi 180) 90)))
    (setq PtDist (distance Startpt (vlax-curve-getPointAtParam VlaObj 2)))
    (vlax-put-property vlaobj 'layer "Router - Green-V groove")
    (vl-catch-all-apply 'vlax-invoke-method (list VlaObj 'explode))
    (if (equal (polar Startpt Ang PtDist)(vlax-curve-getPointAtParam VlaObj 2) 1.0)
    (vl-catch-all-apply 'vlax-invoke-method (list VlaObj 'Offset OffsetDist))
    (vl-catch-all-apply 'vlax-invoke-method (list VlaObj 'Offset (- OffsetDist)))
    ); _end if
    (setq VlaObj (vlax-ename->vla-object (entlast)))
    (vl-catch-all-apply 'vlax-put (list VlaObj 'Layer "Router - Blue - Cuts"))
    (vl-cmdf "explode" (entlast))
    (setq sset (ssget "_P"))
    (setq num -1)
    (repeat (sslength sset)
    (setq VlaObj (vlax-ename->vla-object (ssname sset (setq num (1+ num)))))
    (setq StartPt (polar (vlax-get VlaObj 'StartPoint)(vlax-get VlaObj 'Angle) OffsetDist))
    (vl-catch-all-apply 'vlax-put (list VlaObj 'StartPoint StartPt))
    (setq EndPt (polar (vlax-get VlaObj 'EndPoint)(- (vlax-get VlaObj 'Angle) pi) OffsetDist))
    (vl-catch-all-apply 'vlax-put (list VlaObj 'EndPoint EndPt))
    ); _end repeat
    ); _end while
    ); _end defun
    Otherwise, since you want to explode the selected rectangle I took another shot at writing the program. I cleaned it up a little. I also put in the layer names you used in your code. I guessed at the order you placed them in. Give it a try and let me know if that works for you. Thanks.
    Code:
    (defun c:offsetpline (/ *error* OffsetDist VlaObj)
    (vl-load-com)
    ); _end defun
    (while (setq VlaObj (vlax-ename->vla-object (car (entsel "\nSelect a Rectangle: "))))
     (vl-catch-all-apply 'vlax-put (list VlaObj 'Layer "Router - Green-V groove"))
     (foreach Obj (vl-catch-all-apply 'vlax-invoke (list VlaObj 'explode))
      (vl-catch-all-apply 'vla-offset (list Obj (- OffsetDist)))
      (vl-catch-all-apply 'vlax-put (list (vlax-ename->vla-object (entlast)) 'Layer "Router - Blue - Cuts"))
     ); _end foreach
      (vl-catch-all-apply 'vla-offset (list Obj OffsetDist))
     ); _end foreach
     ); _end if
    ); _end while
    ); _end defun
    jsowinski
  4. #24
    Senior Member
    Manufacture
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    159
    That works good...on ? is there a way to make so i can select multiple rectangles at once?
  5. #25
    Junior Member
    Architecture 2013
    Jul 2011
    10
    Give this a try. Just hit enter when you're done selecting rectangles.
    Code:
    (defun c:offsetpline (/ *error* OffsetDist num Rset VlaObj)
    (vl-load-com)
    ); _end defun
    (princ "\nSelect the rectangle(s) you want to offset: ")
    (setq num -1)
    (if (setq Rset (ssget '((0 . "LWPOLYLINE"))))
     (repeat (sslength Rset)
      (setq VlaObj (vlax-ename->vla-object (ssname Rset (setq num (1+ num)))))
       ); _end foreach
       ); _end foreach
      ); _end if
     ); _end repeat
    ); _end if
    ); _end defun
  6. #26
    Senior Member
    Manufacture
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    159
    That worked Great thanks.....
  7. #27
    Junior Member
    Architecture 2013
    Jul 2011
    10
    You're welcome.
  1. Trimming Lines within a rectangle
    By Sundar in forum .NET, ObjectARX & VBA
    Last Post: 20th Jan 2012, 05:19 am
  2. finding distance between offset lines
    By fisher22 in forum AutoCAD Beginners' Area
    Last Post: 6th Jul 2011, 06:40 pm
  3. automatic offset lines?
    By stephenward in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Jul 2009, 11:07 am
  4. offset 2 lines add dimensions and tag
    By gazzalp in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Dec 2008, 12:35 pm
  5. How to separate text into individual lines?
    By Chris333 in forum AutoCAD Beginners' Area
    Last Post: 29th Oct 2007, 01:14 pm
Tags for this Thread
