Emily Posted February 11, 2012 Share Posted February 11, 2012 I am in the 3d modeling view, and have extruded closed polylines. when i go to subtract the object inside the other it won't subtract the command says failure in face-face intersection merging algorithm> I don't know how to fix it. any help at all would be appreciated. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 11, 2012 Share Posted February 11, 2012 Post the DWG file and someone here will take a look at it. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 11, 2012 Share Posted February 11, 2012 Welcome to CadTutor. Assuming the all of the objects in the operation are solids, you may try "Check" on the Solid Editing tab to see if AutoCAD can confirm them as valid solids. Can you post the drawing? Quote Link to comment Share on other sites More sharing options...
Emily Posted February 12, 2012 Author Share Posted February 12, 2012 unfortunately I am doing this project for a friend who still has a pending patent on it, so i cannot post the Dwg. I tried checking it, and got it says its a 3d object but its not acting like it. i was wondering if i could somehow reconvert it to a surface or a solid, but i have no idea how. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 12, 2012 Share Posted February 12, 2012 No guarantee, but you could try EXPLODE to turn it into surfaces/regions, then SURFSCULPT to turn it back into a solid. Quote Link to comment Share on other sites More sharing options...
Emily Posted February 12, 2012 Author Share Posted February 12, 2012 i attached a similar object that I'm having trouble with. please help 45.dwg Quote Link to comment Share on other sites More sharing options...
nestly Posted February 12, 2012 Share Posted February 12, 2012 (edited) I got an warning that the drawing was not created in an Autodesk application, so I'm guessing AutoCAD is having trouble interpreting some of the geometry (ie the underlying spline) I exploded the solid into regions, then again into the splines, and zooming in reveals some inconsistencies, including a "loop" at the top of the object. I didn't have any luck modifying and extruding the splines... I still got an invalid solid, but using PEDIT to convert the splines to Polylines works, albeit not as smooth as a spline. Edited March 14, 2012 by nestly Quote Link to comment Share on other sites More sharing options...
kencaz Posted February 12, 2012 Share Posted February 12, 2012 If you increase your scrolls extrusion height or reduce the plate height so the scroll passes completely through your subtracting object. It will work fine. KC Quote Link to comment Share on other sites More sharing options...
nestly Posted February 12, 2012 Share Posted February 12, 2012 Very clever. I'll have to remember that one. Quote Link to comment Share on other sites More sharing options...
Emily Posted February 13, 2012 Author Share Posted February 13, 2012 oh ok got it. Thank you very much, that helps. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 13, 2012 Share Posted February 13, 2012 You also can use _PRESSPULL for this. PRESSPULL Quote Link to comment Share on other sites More sharing options...
Jordan27 Posted September 23, 2014 Share Posted September 23, 2014 Hey Guys, I too am having the same problem with not being able to subtract / getting the same error. Have attached my file. Just wanting to remove the centres of the letters. Letter vector text was created using Adobe Illustrators export to DXF function so is probably the cause of the problem. Have tried making letter outline thin with inner tall which passes al the way thru but to no avail. (as per kencazs suggestion - although I downloaded the above file - 45.dwg - Please help! Thanks in advance lancewood.dxf Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 23, 2014 Share Posted September 23, 2014 (edited) Lancewood Terrace as a 3D solid. 3D_Solid Lancewood.dwg I used the Region, Subtract and Extrude commands. Edited September 23, 2014 by ReMark Quote Link to comment Share on other sites More sharing options...
Jordan27 Posted September 24, 2014 Share Posted September 24, 2014 Awesome thanks heaps ReMark !!!! Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 24, 2014 Share Posted September 24, 2014 The triangle in the first "A" appears a bit squirrelly - too many coincident Control Vertices, I think. May cause down steam problems. Quote Link to comment Share on other sites More sharing options...
