+ Reply to Thread
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
  1. #1
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2011
    Posts
    29
    Drawing Need help for penn foster civil drafting project
    Hi everyone
    I am working on civil drafting with Autocad proect and stumpted on drawing the proposed driveway and building site(plate2).I have also got through the old threads but couldn't get,how to draw the driveway layout cut and fill in the lower left corner of my drawing.and new contours on both stde of the driveway.I have attached my dwg. and work done on this project.please do me a favor and have a look on that,point out my descrepencies and guide me to accomplish my project.we need to keep the driveway and house level at elevation 180 with recommended angle of repose 1.5:1.
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,022
    Default
    Re: existing site plan.
    Some of your contours do not look correct.
    I think the spot elevation on the far left should be 21 and not 2.1 don't you?
    The loop in the 120 ft. contour isn't right and the way the 130 ft. contour is formed does not appear to be correct either.
  3. #3
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2011
    Posts
    29
    Default
    Hi
    Good morning
    Thanks for guidence.I have attached both dwgs. after making corrections.The 1st elevation of row 6 is 2.1(as printed in project book),but i made it as 21, I am working on plate 3 now.If you find anything wrong in my dwgs. please feel free to let me know and I would really appericiate that.I have taken off today just to try finish this assignment at earliest possible.[ATTACH] 32914[/ATTACH]ICIVIL DRAFTING PROJECT (DRAFTING THE EXISTING SITE PLAN (PLATE-1) TO BE SUBMITTED.dwg
    Thanks
  4. #4
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Nov 2011
    Posts
    29
    Default
    Hi everyone
    I need help for civil drafting project please.I am totally stuck now.Couldn't figure out to show section A and section B profiles. I have been trying to draw these sections for a couple of days but results do not match with screen shots.Images already we have on this site for this project are not clear.I would really appericiate if someone help get get out of this problem.I am very v frustated now.
    Thanks
  5. #5
    Junior Member
    Using
    AutoCAD 2010
    Join Date
    Sep 2012
    Posts
    16
    Default
    I am having trouble with the last 2 plates on this project Im lost I cant even start because it seems as if they want me to continue a drawing I dont have
  6. #6
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,022
    Default
    That would be Plate 3 and 4 that you are referring to right?
  7. #7
    Junior Member
    Using
    AutoCAD 2010
    Join Date
    Sep 2012
    Posts
    16
    Default
    yes sir from what Ive seen people are havin no problem starting it but i dont know how to maybe pennfoster took material out of the booklet to save money I do know that they have taken books out of the program which screwed the structural project up by refferencing something i dont have
  8. #8
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,022
    Default
    I'm not sure I follow you.
    To my knowledge Penn-Foster has not removed any material in the PDF files containing the instructions for each project (civil, structural, etc.). They do however make references to additional materials, as I have noted in the instructions for the structural project, which I always assumed each student received as part of the course. If I were a P-F student and was told to see another publication that I did not have I would contact one of the instructors and request it. After all, you did pay good money for this course did you not?
    In regards to the civil project you speak of what information are you missing specifically?
    The date on the PDF file I have is from Sept. 2011. Plate 3 is supposed to be a drawing of the Driveway Profile and Section A Profile. Plate 4 is supposed to be a drawing of the Section B Profile. If I am not mistaken the cut lines for the sections were supposed to be shown on Plate 2. Is this the information you have?
  9. #9
    Junior Member
    Using
    AutoCAD 2010
    Join Date
    Sep 2012
    Posts
    16
    Default
    im not sure but for the amount of work i have seen people doing for each drawing 2 steps is very overwhelming to think i could produce results it gives me a scale and tells me the point of station 0+00 and goes on about hatch and thats it from what the booklet has givin me for the driveway profile
  10. #10
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,022
    Default
    I would have to take another look at the actual instructions. I did not take the course. I was given the drawings by another member of this forum who did take the course. He was assisting other students like yourself but could no longer do so. He asked me if I could lend a hand when necessary but made me promise not to attach his completed DWG files to any of my posts. He was OK with screenshots though. Most of the ones you see in many of the threads regarding the civil project are taken directly from his drawings. He got an "A" for the course by the way.
Similar Threads
  1. Penn Foster Drafting with Autocad
    By sethtb1 in forum Student Project Questions
    Last Post: 27th Dec 2012, 05:02 pm
  2. Penn and Foster Structural Project Help
    By robxfinch in forum Student Project Questions
    Last Post: 20th Nov 2011, 03:31 am
  3. Penn Foster Oleson Village project
    By bracken2 in forum Student Project Questions
    Last Post: 1st Aug 2011, 04:07 pm
  4. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
  5. Penn Foster help with HVAC/sheet metal Drafting
    By paisis123 in forum Student Project Questions
    Last Post: 15th Jun 2011, 10:19 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
