Arnc Posted February 13, 2012 Share Posted February 13, 2012 Hello, maybe anyone knows, how to make end of the pipe punched like in the picture? I thought about loft command, but I failed with it. So maybe Inventor has punch command? And other question, about rivet, I can't find it in the library, is my library not full, or Inventor doesn't have such standard parts? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 13, 2012 Share Posted February 13, 2012 The feature will be made with Loft (attach your attempt here). Attach screen capture of what you see in your Rivets library. In any case, it should take less than 5 minutes to create a Rivet. Quote Link to comment Share on other sites More sharing options...
Arnc Posted February 14, 2012 Author Share Posted February 14, 2012 What's about rivet, so now everything is ok, I found it, thanks. And now punching, I tryed, make punched from both side (Ramstis1), that flat part would be in the center of the pipe, and I think, I made it quite well, but please comment, maybe it is the easier way. But how to make punch for top frame I still do not know, so please help. Punch should be like in the CAD drawing. frame.ipt Ramstis1.ipt top frame.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 14, 2012 Share Posted February 14, 2012 I will try to post an example in the next couple of days that is a bit more realistic than your model. There are a couple of tricks involved. Quote Link to comment Share on other sites More sharing options...
Arnc Posted February 21, 2012 Author Share Posted February 21, 2012 Ok, I will be waiting to Yours post. And during that time try to make by my way. Quote Link to comment Share on other sites More sharing options...
