+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
  1. #21
    Full Member
    Using
    Mechanical 2010
    Join Date
    Feb 2012
    Location
    Planet Earth
    Posts
    27
    Default
    now, i have uploaded. the file i take the DATA Extraction from and
    the file i want it to link to.
    first i start DATAEXTRACTION, pick what blocks i want to extract. after what attributes i want.
    the i go make the DATALINK make it as on picture on post #14 even tried with ReMark´s change to it.
    Then i check if alle the collums are in right ordre.
    after that i press NEXT
    and i get OUTPUT OPTIONS
    and make a cross in both INSERT DATA EXTRACTION TABLE INTO DRAWING and OUTPUT DATA TO EXTERNAL FILE (.xls .csb .mdb .txt)
    then i choice the placement of my sheet aaaaand NEXT
    now i am at table style and choice STANDARD
    for formatting the table i use MANUALLY SETUP TABLE
    under that i select TITLE - HEADER - DATA
    and i set a cross in USE PROPERTY NAMES AS ADDITIONAL COLUMN HEADERS.
    then i press NEXT and after that FINNISH
    after that i place the table in the drawing and it pops up with a DATA LINK HAS CHANGED sign in the bottem.
    I press it and this happens:
    Command: _DATALINKUPDATE
    Select an option [Update data link/Write data link] <Update data link>: _U
    Select objects or [Data link/all data linKs]: _D
    Enter data link name or [?]: Data Extraction - Fluid Bed Drier.dxe
    2 object(s) found.
    2 object(s) updated successfully.
    if i go on the sheet i looks good, but if i change it and saved it and closes it. i should say in AutoCAD there is an update ready?
    NOTE: at that point i have had close the drawing i have made it from in case that might can give an issue
    its here it begins to get fuggy, what i am doing wrong id think also i see there a way to get it to copy my excel with the extra fane too? when i extract? i am totally lost on what to do now lol.
    any ideas, what there might be wrong are very welcome
  2. #22
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    I see the saga still continues. I must have missed it in a previous post but it appears you used the DATAEXTRACTION command to create this table. That may be at the root of the problem you are having.
  3. #23
    Full Member
    Using
    Mechanical 2010
    Join Date
    Feb 2012
    Location
    Planet Earth
    Posts
    27
    Default
    okay? have any solutions to it? or is it a AutoCAD error? hehe
  4. #24
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    AutoCAD error? I wouldn't say that exactly. AutoCAD only does what the user instructs it to do which would make this an OIE (Operator Induced Error).
    Solution? Not at the moment. I would have to try and replicate the steps you followed to see what could be salvaged or go about the process in a different manner.
    Why don't you fly over here to the U.S. and we'll go over this together at my computer.
  5. #25
    Full Member
    Using
    Mechanical 2010
    Join Date
    Feb 2012
    Location
    Planet Earth
    Posts
    27
    Default
    hehe i would not mind a vacation.
    but autocad could have got an (Operator Induced error) from the programmer, that program help making that part but then again, they should have tested it.
    and totally agree, it could be myself doing something wrong, first time working with Data Extraction.
    But thanks alot if you wanna check it, you are a
  6. #26
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    I would hold off handing out any gold stars for the moment if I were you. The problem remains unsolved.
    As far as the program goes, the programmers at AutoDesk, as good as they are, cannot fully anticipate all the different ways someone will attempt to use various commands to solve a problem. Remember too that data extraction was an AutoCAD feature prior to the introduction of Tables and Data Links. Maybe it was assumed the user would use one method or the other and not try to combine the two. See what I mean?
  7. #27
    Full Member
    Using
    Mechanical 2010
    Join Date
    Feb 2012
    Location
    Planet Earth
    Posts
    27
    Default
    so what you are saying is, i cant make my attributes from an dynamic block update from an excel sheet there are linked to this drawing in some way?
  8. #28
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    I do not have enough knowledge to definitively answer that question at the moment. I would not jump to any conclusions if I were you.
    I'm kind of surprised that you did not test this method, but on a much smaller scale, before this or did you?
  9. #29
    Full Member
    Using
    Electrical 2011
    Join Date
    Apr 2011
    Posts
    88
    Default
    Use attout and attin (express tools)
    Select all blocks or make a selection (qselect), command Attout.,it saves it as a txt file. open it with Excel, edit wat you want to edit, Save it as a txt file....done. Go back to Autocad, command, ATTIN, select the txt file..........done
    Pmxcad
  10. #30
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,104
    Default
    Although ATTOUT and ATTIN will work it does take more effort to update both the drawing and Excel especially if changes are frequent in nature.
Similar Threads
  1. Insert an Excel sheet into autocad
    By Sudhir in forum Tutorials & Tips'n'Tricks
    Last Post: 17th Dec 2012, 06:16 am
  2. AutoCAD LT Freezes when I attempt to reference an excel sheet
    By naknakkus in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Nov 2009, 11:24 am
  3. about excel sheet connect to autocad
    By ianlcc in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Jun 2009, 01:29 pm
  4. updating tables from autocad to excel
    By chelsea1307 in forum AutoCAD General
    Last Post: 11th Feb 2009, 06:46 pm
  5. Exporting Attributes to an excel Spread Sheet using AutoCAD 2008 VBA
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jan 2008, 09:36 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
