Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 80
  1. #11
    Forum Newbie
    AutoCAD 2009
    Feb 2012
    2
    I remember changing .dxf into .dwg without any issues.
    Not tried changing it back the other way.
    Simple method I tried (using older versions), was just to change the extension - right click and rename the .dwg bit to .dxf
    Let me know...
  2. #12
    Senior Member
    bill_borec's Computer Details
    Windows 7 - 64 Bit
    Dell XPS
    Intel i7-2600
    8 GB
    AMD Radeon HD 6700
    Dual 24"s
    Civil
    bill_borec's Discipline Details
    Civil PE
    Civil
    Water Resources (Water/Sewer/Storm) Water/Wastewater Treatment Design
    Civil 3D 2013
    Jan 2012
    43.3630N 124.1947W
    166
    Myself, that won't work...just changing the file extension will not result in an operable file...you can't change a .doc to a .pdf just by changing the file extension. You need to convert it to the new file format. In this case, there is a conversion to take place. The drawing needs to be simplified to make it backward compatible (e.g. MTEXT, dynamic blocks, TTF, etc.).
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Object enablers? What other program(AutoCAD vertical) provided content used in this drawing?
  4. #14
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    Quote Originally Posted by bill_borec View Post
    That that is correct. Renaming only works for a .bak file that was created by Autocad. If you need to recover a damaged or lost drawing, you can look for a file with the same name with the .bak extension, change it a .dwg extension and Autocad will open the file. You can not simply change a dwg to dxf...they are two completely different file formats. The dxf is an ascii (or sometimes binary) format that can be used by other cad and graphics programs to exchange files before others had emulated the dwg format.
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
  5. #15
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    Download TruView from Autodesk and save it, then DXF out.
    Murph
    Need a boat or camper for the weekend?
  6. #16
    Full Member
    AutoCAD 2007
    Jun 2009
    66
    Quote Originally Posted by SLW210 View Post
    Try -exporttoautocad (note the - in front).
    I get the same error message if I try this.
  7. #17
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Quote Originally Posted by Murph_map View Post
    That works, but not any better than using Autocad. It's the same saveas engine. If you have the new drawing objects discussed earlier in the drawing, Trueview won't convert them any better than Autocad will.
  8. #18
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Can you post the .dwg file?
  9. #19
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    Have you tried AECOBJEXPLODE before trying to save as DXF?
  10. #20
    Full Member
    AutoCAD 2007
    Jun 2009
    66
    Quote Originally Posted by Jack_O'neill View Post
    You'll have to dumb down the fonts as the others suggested especially if you are going to the R12 DOS version. R12 for windows supported true type fonts after a fashion, but it didn't do it very well. If you've used any mleaders, they will have to be changed to leaders. Explode any dynamic blocks, as they will not be supported either. There's more stuff to change, but I can't recall it right off the top of my head. A lot of the drawing objects in use today are not backward compatible.
    Hmmm. yeah I am not sure where to start with this. I dont know how to do this stuff...........sorry.
    Thanks for the response though.
  1. Frustrated about Speciality Edge
    By schlosser37 in forum AutoCAD General
    Last Post: 21st Oct 2010, 11:08 am
  2. Trying to create new line and getting frustrated.
    By Gratitude1977 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 20th Oct 2010, 08:34 pm
  3. frustrated with new autocad 2009
    By TheNewGuy in forum AutoCAD Beginners' Area
    Last Post: 18th May 2009, 02:15 pm
  4. I know why I'm so frustrated
    By arusho in forum Autodesk Inventor
    Last Post: 12th Apr 2008, 12:24 am
  5. frustrated...
    By chrisdarmanin in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jan 2007, 01:55 pm
