Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 80 of 80
  1. #71
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Perhaps an alternative would be to discover exactly why your attempts to create a DXF file from your own AutoCAD went awry. How adept are you with AutoCAD
    P.S. pretty please do not start any more threads. I am getting quite confused as some answers are not to the latest Update of the latest Update. The whole thread could just as successfully been all in one, and the way the forum is set up, the latest replies are easily arrived at.
  2. #72
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,124
    I merged all your threads into this one.
  3. #73
    Full Member
    AutoCAD 2007
    Jun 2009
    66
    Murph
    No I suppose that I don't really need the clients plans in the map. Its purely a security blanket for me as I like to be able to see if the tree positions surveyed on site appear in the correct place.
    To be honest my problem is that I don't know how to merge the survey data with the clients drawing. Unless the client's drawing is already aligned to the National Grid - won't my tree positions be way out? Also I often get drawings from clients that are not oriented to the North (often because they want the site plan to fit a certain size of paper). Any advice and assistance with this would be greatly appreciated.
    eldon - yes you are correct here! I tried downloading DraftSight and changing my drawing to a R12 DXF. When loading the file I get asked for LTypeshp.shx if I opt for cancel and save the drawing as an R12 DXF, PocketGIS is still unable to recognise the file.
    Sorry for the threads thing - I obviously need to study forum etiquette!
    SLW210 - Thanks for merging and sorry.
    Everyone - Thank you for your patience and assistance thus far.
  4. #74
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    I expect that you cheer when the drawing is set to OS grid. Your posted drawing seems to be SE of Inverness.
    When drawings are not aligned to OS but to paper, you will have to take readings to features which appear on the ground, and then in the office, you can align their drawing to your measured features - a simple procedure.
    Now, have you tried, in your AutoCAD, to explode everything? You may have to do the Explode more than once to get it in a format suitable for PocketGIS. Then when you make the DXF file, try to use the Option to select Objects, rather than to do an overall DXF, which may pick up various inedible drawing set-up factors.
  5. #75
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    Quote Originally Posted by Treehugger View Post
    Murph
    This is were using a Civil application pays off, if plan on do very much of this type of work you need to plan on paying for Civil3D or MAP3D or you'll pay with the headaches and lost clients.
    Now to help solve your issue with out DXFing that you can not get to work. When you're out there getting the trees also get 2 or three points that are on the dwg that you can later ID when you get back in the office. Points like the property corners or edges/centerline of the road, or anything that may be in the site plan. Then when you bring in the points move/rotate/align/scale the site plan to match. Then you should be able to save the points info from the GPS/survey to text format and use the X,Y, location to plot the points in the dwg.
    Murph
    Need a boat or camper for the weekend?
  6. #76
    Full Member
    AutoCAD 2007
    Jun 2009
    66
    Quote Originally Posted by eldon View Post
    How do I do this please?
  7. #77
    Full Member
    AutoCAD 2007
    Jun 2009
    66
    Quote Originally Posted by Murph_map View Post
    What do these applications do that AutoCAD Doesn't?
    Can they be used as standalone applications or do they require AutoCAD to function?
  8. #78
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    When you hit the SaveAS button and a dialogue box comes up. (I have an earlier version than you, so perhaps the picture isn't exact). At the bottom you select Files of type - AutoCAD R12 DXF. At the top of the box at the right hand end is Tools. Select that and choose Options (at the bottom of the list). Then select DXF Options and select the "Select objects". Then press OK and you will be invited to select objects. Window the whole drawing, and there you are
  9. #79
    Win 7, Win 8
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    924
    They allow you for one to use a coordinate system NAD83 (Lat/Lon) or State Plane or create your own to use. They also allow you to work most survey units out there, pick in points from the survey unit and draw them for you in the dwg. They make better use of aerial images and Google Earth, work with a number of GIS format files out there for free. Depending on what part of the world you're working in there's ton of free stuff out there for mapping and locating features in the real world.
    AutoCAD Civil 3D is build on top of AutoCAD Map3D which is build on top of AutoCAD so with Civil 3D you have 3 programs in one, autocad, Map3D a GIS program and Civil3D a civil design program.
    Murph
  10. #80
    Full Member
    AutoCAD 2006
    Feb 2011
    94
    has anyone found a solution to this error? my office mate is having the same error message. Shes trying to save a drawing made from Autocad Map 3d to Autocad 2011.
  1. Frustrated about Speciality Edge
    By schlosser37 in forum AutoCAD General
    Last Post: 21st Oct 2010, 11:08 am
  2. Trying to create new line and getting frustrated.
    By Gratitude1977 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 20th Oct 2010, 08:34 pm
  3. frustrated with new autocad 2009
    By TheNewGuy in forum AutoCAD Beginners' Area
    Last Post: 18th May 2009, 02:15 pm
  4. I know why I'm so frustrated
    By arusho in forum Autodesk Inventor
    Last Post: 12th Apr 2008, 12:24 am
  5. frustrated...
    By chrisdarmanin in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jan 2007, 01:55 pm
