Results 1 to 6 of 6
    Junior Member
    barefootbob's Computer Details
    Mac and PC - Lion / Windows 7
    Civil 3D 2012
    Feb 2012
    Chicago
    11
    Default Manipulating a SHP
    I have received one (1) large SHP file that has all of the individual municipal/village boundaries for a larger city. I guess the same question would apply to isolating certain rivers or streams from a SHP file that contains all in the state. Is there any way I can extract or change these shape areas separately? The style editor unfortunately seems to only make change the entire SHP file when I make changes to the color fill, outline, etc.
    In summation, I would like to make individual SHP files of an original that has multiple boundaries.
    Thanks in advance.
    Bob
    Senior Member Emigrato's Avatar
    not applicable
    Sep 2011
    116
    I would try to check out the object data of that huge shape: maybe some vectors have e.g. "building" as attribute, others "river", and so on.
    In this case, you can select them by attributes, and then _MAPEXPORT to individual shapefiles, sir.
    Forum Newbie
    AutoCAD 2010
    Feb 2012
    1
    I have no idea what to do sky on
    Junior Member
    Civil 3D 2012
    Feb 2012
    Chicago
    11
    Still, confused. Even when I can look at the metadata and try to export it the options are only to a .csv file. Does this original file have to be manipulated back in regular ACAD (with values attached) and then the specific changes made there, crate new individual shapefiles and then reimport them individually? - It seems that the 'checking out' option does not quite so what I want it to either.
    Lost...
    Thanks
  5. #5
    not applicable
    Sep 2011
    116
    Well, zip that shapefile and send me by email to: sieradzgmail.com
  6. #6
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    XP,Visa, Win7
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    TN or KY depends if I'm at work or home.
    598
    Are you using Data Connect or mapimport to bring in the shp file? You can style based on the data or even query and display by the data, then save to another format etc. Say you have a shp file of all the cities boundry of a state, as long as the city name is part of the data you can display just the boundry of "Anytown" then save that to another dwg/sdf/layer file depending on how you bring in the shp file.
    Murph
    Need a boat or camper for the weekend?
  1. Manipulating dimension values
    By silverfish in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2012, 11:32 am
  2. manipulating geometric objects
    By cotsy in forum AutoCAD Beginners' Area
    Last Post: 22nd Jan 2011, 06:22 pm
  3. Manipulating JPEGs in Autocad
    By Jovial in forum AutoCAD Beginners' Area
    Last Post: 9th Mar 2009, 03:50 pm
  4. Manipulating Autocad from Excel
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Nov 2005, 11:01 pm
  5. Manipulating my background
    By hyposmurf in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Jun 2004, 07:21 pm
Tags for this Thread
