wblock
metaldan
Hi
I search the way to make a WBLOCK command in vb.net. I have to ask th user to select some BOM line, with that, ask him to select different object to make wblock with them.
did someone can help me.
Save a drawing usual way as ".dwg",
then you can save them after as ".dxf" using Interop Namespace
Or you may want to try this slow method using Reflection:
Imports System.Runtime.InteropServices
Imports System.Reflection
Imports System.Globalization
Imports System.Collections
Imports Autodesk.AutoCAD.Runtime
<Assembly: CommandClass(GetType(OldHorse.ReflectionCommands))>
Namespace OldHorse
   Public Class ReflectionCommands
       <System.Security.SuppressUnmanagedCodeSecurity()> _
       Public Shared Sub DwgToDxf(acadver As String, fname As String, dxfname As String)
           Dim thisThread As System.Globalization.CultureInfo = System.Threading.Thread.CurrentThread.CurrentCulture
           thisThread = New System.Globalization.CultureInfo("en-US")
           Dim appProgID As String = "Autocad.Application" + "." + acadver
           ' get reference on interface  IDispatch
           Dim AcadType As Type = Type.GetTypeFromProgID(appProgID)
           ' run AutoCAD
           Dim AcadApp As Object = Activator.CreateInstance(AcadType)
           Dim visargs() As Object = New Object(0) {}
           visargs(0) = True
           ' make application visible
           AcadApp.GetType().InvokeMember("Visible", BindingFlags.SetProperty, Nothing, AcadApp, visargs, Nothing)
           Dim AcadDocs As Object = AcadApp.GetType().InvokeMember( _
       "Documents", BindingFlags.GetProperty, Nothing, AcadApp, Nothing)
           ' define arguments to open file
           Dim args() As Object = New Object(1) {}
           args(0) = fname
           args(1) = False 'read-only=false, in other words we open file in write mode
           ' try open file
           Dim AcDoc As Object = AcadDocs.GetType.InvokeMember( _
           "Open", BindingFlags.InvokeMethod, Nothing, AcadDocs, args, Nothing)
           Dim Util As Object = New Object
           Try
               ' get active document
               AcDoc = AcadApp.GetType.InvokeMember( _
           "ActiveDocument", BindingFlags.GetProperty, Nothing, AcadApp, Nothing, Nothing)
               'Save document in desired DXF format:
               '' DXF formats:
               '' 13 = ac2000_dxf, 25 = ac2004_dxf, 37 = ac2007_dxf
               AcDoc.GetType().InvokeMember( _
                    "SaveAs", BindingFlags.InvokeMethod, Nothing, AcDoc, New Object() {dxfname, 37})
               ' Close source document
               'Dim closeargs() As Object = New Object(1) {}
               'closeargs(0) = True
               ' with same name
               '    closeargs(1) = fname
               ' close source document
               ' Try close active document
               '        AcDoc.GetType().InvokeMember( _
               '        "Close", BindingFlags.InvokeMethod, Nothing, AcDoc, closeargs, _
               'Nothing, System.Globalization.CultureInfo.CurrentCulture, Nothing
               ' simplified syntax to close document
                       "Close", BindingFlags.InvokeMethod, Nothing, AcDoc, Nothing)
               ' Try quit application
               "Quit", BindingFlags.InvokeMethod, Nothing, AcadApp, Nothing)
               MsgBox("Done, check a dxf file")
           Catch ex As System.Exception
               MsgBox("Error: " & ex.Message & vbLf & "Trace: " & ex.StackTrace)
           Finally
               ' garbage clean
               ' release AcDoc.
               releaseObject(AcDoc)
               ' release AcadDocs.
               releaseObject(AcadDocs)
               ' release AcadApp.
               releaseObject(AcadApp)
               ' call garbage cleaner immediatelly
               GC.WaitForPendingFinalizers()
               GC.GetTotalMemory(True)
               ' restore current culture
               System.Threading.Thread.CurrentThread.CurrentUICulture = thisThread
           End Try
       End Sub
       Public Shared Sub releaseObject(ByVal obj As Object)
           Try
               System.Runtime.InteropServices.Marshal.FinalReleaseComObject(obj)
               obj = Nothing
               obj = Nothing
           Finally
               GC.Collect()
           End Try
       End Sub
   End Class
End Namespace
then in caller class try something like this:
(tested on 2009 only many times)
<CommandMethod("SaveAsDxf", "sdxf", CommandFlags.Session Or CommandFlags.Modal)> _
Public Sub TestSaveAsDXF()
Dim acver As System.Version = Autodesk.AutoCAD.ApplicationServices.Application.Version
Dim numver As String = acver.Major.ToString
'' source drawing after executing the WbloneObjects method
Dim fileName As String = "C:\Test\foo.dwg"
'' save document as DXF file
Dim dxfname As String = "C:\Test\foo.dxf"
ReflectionCommands.DwgToDxf(numver, fileName, dxfname)
End Sub
~'J'~
  • 2 weeks later...
Thank's Jeff H
your DATABASE.DXFOUT method work perfectley.
I put it in a loop to pass all the item in my BOM. For each item, the user select the objet, the vb.net open a new acad document ( temporaly ) , database.dxfout it, and after a close the document.
The Dxf is saved perfectly but it don't close it. I have 1 temporaly document for each item.??? wierd. Maybe a put the END USING database at the wrong place.
i will check it tomorow.
Hi I found the way
instead of the DOCUMENT.DISPOSE method, I use DOCUMENT.ClLOSEANDDISCARD()
THANK'S FOR YOUR HELP
hi
A error apear when a run my progrm on a 64bit machine ( win 7 64bit + acad 201264bit) but not on winxp 32 bit + acad 2008
After that line
acDbNewDoc.DxfOut("R:\IN BEND\" & Left(DANCART.DESSIN, 8) & "-" & BOML.ITEM & ".dxf", 16, DwgVersion.Current)
i receive this error
INTERNAL ERROE : !dbobji.cpp@7319: eNotOpenForWrite
after, i have a 0 ko dxf file.
Did you have any ideas???
The R:\IN BEND is on a Network, i try to make a manualy saveas DXF at the same location, with the same name and it work.
