+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,131
    Default
    Quote Originally Posted by raye215 View Post
    I kept seeing same references to Longbow, but no reviews. My install on Virtual PC WinXP has never worked well -- I get really slow redraws (i.e. when I copy something it takes forever for the aperture to move across the screen to the location I think I've moved my mouse to). I suppose this might be fixed if I figured out how to allocate more memory to the graphics in XP mode? But I also have the cursor issue. Anyway I'm going to try an install of 2007 in Win7. Thanks for the report on your experience Charlie M. If anyone else has any ideas on fixing the XP install of 2004 or ways to install 2007 I'd be much obliged.
    Welcome to the forum.
    Is your WHIPTHREAD set to 3?
    If not try it, should speed you up a bit.
    Volume and repetition do not validate opinions forged in the absence of thought.
  2. #12
    Forum Newbie
    Using
    AutoCAD 2004
    Join Date
    Jun 2012
    Posts
    6
    Default
    Hm didn't know what that was, but it is already set to 3. Thanks for the suggestion
  3. #13
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Feb 2012
    Posts
    6
    Default
    Raye, I hope your copy of 2007 came with a 64-bit and a 32-bit version like my 2008 did otherwise you may be forced to give Longbow a closer look. Good Luck!
  4. #14
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,022
    Default
    There was no 64-bit version of AutoCAD 2007. Read this:
    http://through-the-interface.typepad...d_2008_64.html
  5. #15
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,022
    Default
    The WHIPTHREAD variable controls the way AutoCAD uses the second processor (or core) in a multi-processor computer for display operations.
    • 0 - use only a single processor (default)
    • 1 - regen done on multiple CPUs
    • 2 - redraw done on multiple CPUs
    • 3 - both regens and redraws done on multiple CPUs
Similar Threads
  1. 2010 CAD - slow mouse pointer
    By bobsy852 in forum AutoCAD Beginners' Area
    Last Post: 6th Aug 2010, 09:32 pm
  2. The mouse pointer
    By bmdavis in forum AutoCAD General
    Last Post: 15th Nov 2009, 05:20 pm
  3. mouse pointer problems
    By blue sun in forum AutoCAD General
    Last Post: 4th Feb 2009, 12:00 pm
  4. Problem: AutoCAD mouse pointer sticks on the screen
    By Jim25 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Apr 2006, 11:32 pm
  5. Speed up Mouse Pointer
    By JBullseye74 in forum Hardware & Operating Systems
    Last Post: 14th Mar 2006, 02:49 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
