call tblobjname on a drawing opened as ObjecDBX! Is it possible???????
Ahankhah
Hi all,
the following code shows whether a text style is annotative (written by Lee):
(defun LM:isAnnotative (style / object annotx)
(and
 (setq object (tblobjname "STYLE" style))
 (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative")))))
 (= 1 (cdr (assoc 1070 (reverse annotx))))
Is it possible to call tblobjname on a drawing which is opened as a ObjectDBX?
No, tblobjname is not available through an ObjectDBX interface.
Here is a Visual LISP alternative:
;; Annotative-p  -  Lee Mac
;; Predicate function to determine whether a textstyle
;; is annotative.
;; Written in Visual LISP for compatibility with ObjectDBX
(defun LM:Annotative-p ( doc style )
   (and
       (null
           (vl-catch-all-error-p
               (setq style
                   (vl-catch-all-apply 'vla-item
                       (list (vla-get-textstyles doc) style)
           (lambda ( getvalue / xtype xvalue )
               (vla-getxdata style "AcadAnnotative" 'xtype 'xvalue)
                   (lambda ( elist )
                       (= 1 (cdr (assoc 1070 (reverse elist))))
                   (apply 'mapcar (cons 'cons (mapcar 'getvalue (list xtype xvalue))))
           (lambda ( data )
               (cond
                   (   (eq 'variant (type data))
                       (getvalue (vlax-variant-value data))
                   (   (eq 'safearray (type data))
                       (mapcar 'getvalue (vlax-safearray->list data))
                   (   data   )
Pass it the ObjectDBX Document Object and Style name.
Lee,
would you explain some about getvalue in your code?
;; is annotative.
(and
(null
(setq style
(lambda ( [b]getvalue[/b] / xtype xvalue )
(lambda ( elist )
(apply 'mapcar (cons 'cons (mapcar '[b]getvalue[/b] (list xtype xvalue))))
(lambda ( data )
(cond
([b]getvalue[/b] (vlax-variant-value data))
(mapcar '[b]getvalue[/b] (vlax-safearray->list data))
( data )
I think I found out the answer: You use second lambda as argument of the first lambda and in the second, you use itself (recursively).
You've got it. Its probably more obfuscated / complicated than it needs to be, since I could have instead defined a recursive subfunction called 'getvalue' and called it from within the 'LM:Annotative-p' function to evaluate the variants returned by the getxdata method; but that would be too obvious :)
