Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    not specified
    Feb 2006
    31
    Default need help modelling this circular ramp
    Hi everyone
    Can u cad experts tell how can i model this ramp...see attached image
    i am also attaching the acad file along with it...
    i have no idea how to model this ramp...
    one diversion of the ramp goes down and one goes up to the fountain....level difference is from 0 to 4mtrs....ramp starts from 0 and fountain level is 4mtrs.
    Cad file link www.geocities.com/haneet22/rampdesign.zip
    thanks
    Full Member
    not specified
    Feb 2006
    31
    Please help guys
    thanks
    Full Member
    not specified
    Feb 2006
    87
    This is something where you need alot of measurements to be able to do correctly. Just having a difference in lvl hieght would probably not be enough.
    You could do this a couple of ways tho, use a poly line where the centre of the road is, then make a rectangle and extrude it along the path.
    Or you could subtract lots of solids away from each other until you get the shape of the ramp(s). The first way would prob be easiest.
    But when your working on this look at it in 2 parts. Do the ramp going up first, then do the ramp going down 2nd. But without more informative measurements i cant help with this.
    Full Member
    not specified
    Feb 2006
    31
    man i attached the acad file with this for measurements
    I cudn't get ur first part if i want it to extrude along the polyline how can i make the polyline which is changing its height in z direction
    thanks
  5. #5
    Full Member
    not specified
    Feb 2006
    31
    this forum looks really slow
  6. #6
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Well you could do it using RULEURF. Create a line across the width of the road, at an elevation. Create another line a distance away, say a few feet, at another elevation. Using 'rulesurf' create a surface between them. You could use polar array to create multiple lines along the ramp. Assign elevations. Rulesurf between each. You can probably think of some shortcuts after doing this a while.
  7. #7
    Full Member
    not specified
    Feb 2006
    87
    Sorry i should have checked out the file, ill have a look tonight if i get time
  8. #8
    Junior Member Hammeroid's Avatar
    AutoCAD 2007
    Nov 2005
    London
    12
    Default ramp
    Haneet22,
    Not a straightforward one, but i drew a basic ramp recently using meshes along with the m2s lisp and extruding the kerb profile along a 3d polyline etc. Hope this helps:
    http://www.cadimage.net/postimages/ramp.dwg
  9. #9
    Forum Newbie
    not specified
    May 2006
    1
    Default Circular Ramp
    I just found this site and thought I'd give my input. I have to agree with Safwah. You need to provide some civil measurements (e.g. elevations of road and landscaping, complete dimensions, type of curbing, what the fountain might look like and any other information that'll allow this project to be completed ) Just providing a site plan with none of the above mentioned, would make the task impossible. Sure I could give you a 3D of the drawing if it were flat, but that's not the case. If you can give me what I mentioned and a link to it, I'll give it a stab.
  10. #10
    Full Member VERYCIVILDRAFTER's Avatar
    Civil 3D 2011
    Oct 2005
    Denver, CO
    65
    I don't know where this project is located obviously, but you'll most likely have to conform to some type of maximum slope for disabled persons access. Additionaly you'll need to use minimum slopes for water runoff, and you should probably get a grading plan for your landscaped area... meaning call a Civil Engineer.
    However, if this is a "toy" project.
    You can hand clac various points along the center line pretty easily. Then draw them in.
    V/L=%
    V= Total Vertical Change
    L= Total Horizontal Length
    AutoCAD Civil 3D 2011
