+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Senior Member
    Computer Details
    nicolas's Computer Details
    Operating System:
    Windows 7
    Computer:
    Intel Dual Core 64 Bits
    RAM:
    2 GB
    Using
    AutoCAD 2012
    Join Date
    Jan 2008
    Location
    Port Louis, Republic of Mauritius
    Posts
    332
    Default Linetype Scale System
    Hi,
    I have been adopting a linetype scale system for CENTER & HIDDEN types that works perfect on one drawing but not in another.
    Here it is:
    Globally,
    Measurement:1
    MSLTSCALE:1
    PSTLSCALE:1
    CELTSCALE:1
    LTSCALE:1
    CENTER lines are scale 0.1 (works fine in all drawings and in both 1:30 and 1:4 viewports)
    HIDDEN lines are scale 0.3 (work in one drawing but failed in the second drawing in both 1:30 and 1:4 viewport)
    Setting the HIDDEN lines to 10 works with most other drawing.
    I want to know first of all why this setting of 0.1 CENTER and 0.3 HIDDEN works on one drawing and not on another one in spite of the general settings set alright.
    Regards and thanks,
    Nicolas.
  2. #2
    Super Member
    Computer Details
    nestly's Computer Details
    Operating System:
    Windows XP Professional (32bit)
    Motherboard:
    Intel DG33FB
    CPU:
    Intel Core2 E2220 @ 2.4GHz
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    250GB WD 7200rpm / 320GB WD 7200rpm
    Secondary Storage:
    500GB WD external USB
    Monitor:
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    0.1 & 0.3 seem like they'd be very small dashes, but I guess that's beside the point. Are both drawings using the proper linetype definition file (ie is the Acadiso.lin file being used for an Imperial drawing?)
  3. #3
    Senior Member
    Computer Details
    Operating System:
    Windows 7
    Computer:
    RAM:
    2 GB
    Using
    AutoCAD 2012
    Join Date
    Jan 2008
    Location
    Posts
    332
    Default
    I believe that hidden line being 3x times greater than the center line and in at least one of the drawing it is visually acceptable. In the second case, the hidden line is 100x greater than the center line and that seemed odd through again in that case, it is visually acceptable. The drawing is in ISO given that measurement is 1 or is there another way to check this. As to acadiso.lin, I don't know but I have not touch those files.
  4. #4
    Super Member
    Computer Details
    Operating System:
    Motherboard:
    Intel DG33FB
    CPU:
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    Secondary Storage:
    Monitor:
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    Loading or reloading linetype definition from acad.lin in a ISO drawing will cause it to display 25.4x smaller than the same linetype from acadiso.lin.
    Posting a sample of each drawing may be helpful diagnosing the problem.
  5. #5
    Senior Member
    Computer Details
    Operating System:
    Windows 7
    Computer:
    RAM:
    2 GB
    Using
    AutoCAD 2012
    Join Date
    Jan 2008
    Location
    Posts
    332
    Default
    How do we know the linetype source is acad.lin or acadiso.lin in a metric drawing?
  6. #6
    Super Member
    Computer Details
    Operating System:
    Motherboard:
    Intel DG33FB
    CPU:
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    Secondary Storage:
    Monitor:
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    You can export all the linetype definitions from a drawing with a lisp or vlx and then compare it to acadiso.lin in your AutoCAD support folder.
    Here's a link for lineout.vlx http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3958
Similar Threads
  1. The Solar System Drawn to Scale in AutoCAD DWG - Scale is Everything
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 22nd Feb 2011, 03:14 pm
  2. The Solar System Drawn to Scale in AutoCAD DWG - Scale is Everything
    Last Post: 18th Feb 2011, 03:30 am
  3. Replies: 4
    Last Post: 18th Jan 2011, 12:06 am
  4. Linetype and Linetype Scale!
    By Penfold in forum AutoCAD Drawing Management & Output
    Last Post: 29th Oct 2007, 11:45 pm
  5. Scaling linetype scale with SCALE command?
    By SpeedDemon in forum AutoCAD General
    Last Post: 23rd Jul 2007, 03:28 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
