+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Senior Member
    Using
    not specified
    Join Date
    Feb 2006
    Posts
    247
    Default perpendicular arrow when picked a point on polyline
    Hello to all
    can any one help to draw or insert a perpendicular arrow with attribute on a picked point on polyline or arc or line as in attached dwg
    thanks
  2. #2
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,798
    Default
    Search here for BATTER lsp program the ticks are at 90 just replace the tick block
  3. #3
    Senior Member
    Using
    not specified
    Join Date
    Feb 2006
    Posts
    247
    Default
    thanks BIGAL FOR reply the batter lisp insert perpendicular lines at equal distance no option for insert point
    in addtion to no choice for arrow side
  4. #4
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,798
    Default
    Search a bit more the batter I downloaded picks top and bottom plines it wouldn't take much to add a set distance factor. I have it as batterticks.lsp but I may have renamed it it has no author name in it try TBL also.
Similar Threads
  1. Picked point while picking an entity
    By harilalmn in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2011, 05:17 am
  2. Replies: 1
    Last Post: 29th Aug 2011, 10:00 pm
  3. Perpendicular on Given Polyline with given segment
    By samcoozy in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2010, 02:52 pm
  4. VB.net: Perpendicular lines to a polyline
    By Jozi68 in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Oct 2009, 04:47 pm
  5. Perpendicular on specified point on curve?
    By therock005 in forum AutoCAD General
    Last Post: 1st Feb 2007, 09:57 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
