Results 1 to 5 of 5
    Junior Member
    Civil
    okaloosa_manderson's Discipline Details
    CAD Designer/Public Works
    Civil
    Civil 3D 2012
    Feb 2012
    Okaloosa County, FL
    12
    Default Description Keys/Figure Styles
    I have my Description Keys and Figure Styles set up in AutoCAD Civil 3d 2012, however, when bringing in a .fbk file from our surveyors I am having problems with AutoCAD drawing lines between points with the raw description of "DWY ASPHALT1" and "DWY CONC1". The description key is set to "DWY*", the description key format is "$*" and figure style set to "DWY". Does AutoCAD not look at the raw descritpion to dertime that these are different objects? Do I have to create a new figure style for each type of driveway? All of our driveways weather gravel, rock, asphalt, concrete...whatever...go on layer Driveways_ep also.
    Junior Member
    Civil
    Civil
    Civil 3D 2012
    Feb 2012
    Okaloosa County, FL
    12
    Another question: Is there a way to tag the figure with certain parts of the raw description? IE: If the raw description is "STS RCP 15" (for 15" RCP Storm Sewer pipe) and I want the figure with 15" RCP....
    Senior Member
    Civil 3D 2011
    Jul 2008
    Colorado
    247
    Started to answer this, then realized it involved too many things. I suspect some training in C3D Survey is in order... Too much to cover in a forum post.
    But to help keep you from going down a "bad path", I'll say that you should NOT use different Figure Styles for everything... Huge time wasting lays down that path. Instead, favor "ByLayer" for most of your Style settings (unless they are set to Layer 0 in the Point Style and Point Label Style, maybe). (And in general, make sure NONE of your Objects Layer settings is set to Layer 0, even if it has a suffix or prefix (although that's better than most alternatives).
    Richard 'Sinc' Sincovec
    Manager of Technology - Edward-James Surveying
    Tools for Civil 3D - Quux Software
    Junior Member
    Civil
    Civil
    Civil 3D 2012
    Feb 2012
    Okaloosa County, FL
    12
    I shouldn't use different Figure Styles for everything? I am using FDOT State Kit for Civil 3D and they already have the Figure Styles set up to go to FDOT's layering standards. I only set up the Description Keys for our surveyors so the surveys they do will tie in with the proper point styles and draw figures when necessary on FDOT's preset layers.
  5. #5
    Full Member caddcop's Avatar
    caddcop's Computer Details
    WinXP
    Lenovo ThinkPad Laptop - Dual Screens on Docking Station
    Dell and Viewsonic 22' Widescreens
    Civil
    caddcop's Discipline Details
    CADD Manager - Civil/Survey
    Civil
    Working with Land Desktop 2008 and 2009, Civil 3D 2009, 2010, 2011, 2012 & 2013
    Land Desktop 2009
    Sep 2009
    Maryland (DC Suburbs)
    94
    Our crews use sequence numbers to keep different figures of the same feature separate. DWY1 DWY2 ...
    Use $2 $1 as the format for STS RCP 15.
  1. Autocad 2012 Dim Styles - Leader Styles
    By D_Dub in forum CAD Management
    Last Post: 31st May 2011, 11:41 am
  2. Description Keys
    By wrmurphy81 in forum Civil 3D & LDD
    Last Post: 9th Aug 2010, 03:59 am
  3. Importing Description Keys
    By rlshound in forum Civil 3D & LDD
    Last Post: 17th Mar 2010, 05:29 pm
  4. LDD Desc. Keys import to Civil 3D Point Styles?
    By caddcop in forum Civil 3D & LDD
    Last Post: 13th Mar 2010, 12:12 am
  5. Replies: 0
    Last Post: 15th Nov 2006, 06:10 pm
