dustboy Posted February 24, 2012 Share Posted February 24, 2012 I recently migrated my copy of AutoCAD 2002 to a new PC. It seems to have forgotten some commands, for example rectang and dsettings. Others like line and arc work fine. I've searched this forum and found similar questions, but none of those solutions have worked. The support file path settings seem OK, and acad.pgp looks OK as far as I can tell. Note: I couldn't find the installer when I migrated, so I had to copy all the files by hand, but I'm pretty sure I kept the directories intact. _rectang Unknown command "RECTANG" Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2012 Share Posted February 24, 2012 When you say you "had to copy all files by hand" are you saying that you used cloning software? Quote Link to comment Share on other sites More sharing options...
bill_borec Posted February 24, 2012 Share Posted February 24, 2012 Sounds like a good time for an uninstall-reinstall ACAD. Isn't the ACAD.pgp file just a list of shortcuts and associated commands? Not a list of available commands from ACAD. If you make up a shortcut of XYZ = !@#!^@$^%*$%^** command, ACAD will return with an "unknown command". BTW...Welcome to the forum! Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2012 Share Posted February 24, 2012 I would have used cloning software if I misplaced my installation media. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 24, 2012 Share Posted February 24, 2012 Try _DEMANDLOAD = 3 Sounds like all of your ARX files are not LOADED, you might try APPLOAD. Quote Link to comment Share on other sites More sharing options...
dustboy Posted February 27, 2012 Author Share Posted February 27, 2012 DEMANDLOAD doesn't help, "APPLOAD" is another unknown command.. I used the Microsoft Easy Transfer to move the files from the old XP machine to the new Windows 7 machine. I bought the old PC second hand from a friend, and CAD was already installed, so I don't have the disks. Can't find an installer .exe anywhere on the old drive. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 27, 2012 Share Posted February 27, 2012 Go to Windows Add/Remove and see if you can run a repair. Quote Link to comment Share on other sites More sharing options...
dustboy Posted February 27, 2012 Author Share Posted February 27, 2012 Hmm, ACAD doesn't appear in the list in Add/Remove. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 28, 2012 Share Posted February 28, 2012 That doesn't sound good. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 28, 2012 Share Posted February 28, 2012 So much for relying on Microsoft Easy Transfer. It was easy, it just wasn't accurate. Sounds like some Registry entries have gone missing. Do you still have the old drive? Quote Link to comment Share on other sites More sharing options...
dustboy Posted February 28, 2012 Author Share Posted February 28, 2012 Yes, the old machine is sitting right here, I'm still using it to get work done while I sort out the new one. BTW, thanks for all the help so far. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 28, 2012 Share Posted February 28, 2012 Did you bring everything over from the old drive to the new one? Quote Link to comment Share on other sites More sharing options...
dustboy Posted February 28, 2012 Author Share Posted February 28, 2012 Everything I could find, but that doesn't mean I got it all. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 28, 2012 Share Posted February 28, 2012 Well you could always try again but this time use a proven program like Acronis True Image Home 2012 ($50 U.S.). Quote Link to comment Share on other sites More sharing options...
