Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Forum Newbie
    AutoCAD LT 2011
    Feb 2012
    2
    Default Displacement distance as @(7sin60)<75
    Is there any way to include a trig function in the displacment distance?
    @(7sin60)<75 does not work, but it is what I would like to do.
    I have to calculate it each time and type in something like the following:
    @6.062178<75
    Thanks in advance.
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Try this:
    Code:
    @(* 7 (sin 60))<75
    it should work ... if the angle is 60RADIANS
    For degrees:
    Code:
    @(* 7 (sin (/ (* 60 PI) 180)))<75
    I admit that it is pretty complicated for a beginner, you should read the help file for Lisp expression
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,008
    I'm afraid that the OP had listed LT as his AutoCAD type, so AutoLISP expressions aren’t applicable.
    Regards,
    Mircea
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,008
    An alternative solution is to use Excel to do the calculation and build the displacement string - use cells A1, A2 and A3 to fill your values and copy-paste the concatenated string to AutoCAD command prompt.
    Code:
    =CONCATENATE("@", ROUND(A1 * SIN(A2 * PI() / 180), 5), "<", A3)
    Regards,
    Mircea
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,970
    Or another alternative is to use the Windows calculator, and again copy-paste the answer into the command line.
  6. #6
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    You can use quickcalc in AutoCAD transparently and insert with Apply.
  7. #7
    Forum Newbie
    AutoCAD LT 2011
    Feb 2012
    2
    thanks everyone
  8. #8
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,970
    Quote Originally Posted by SLW210 View Post
    Yes, I was wondering whether LT had that facility.
  9. #9
    Senior Member khoshravan's Avatar
    khoshravan's Computer Details
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    422
    Quote Originally Posted by msasu View Post
    Code:
    Regards,
    Mircea
    The above expression is written in Excel. Is it correct?
    Then how do you send this expression into cad? copy/paste?
  10. #10
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,008
    Quote Originally Posted by khoshravan View Post
    That's true, it is a formula for Excel. I proposed that to help OP build desired expresion since on LT there is no AutoLISP available.
    The method is indeed Copy/Paste - I already stated that into my post; just be careful to copy from cell, not from formula field.
    Regards,
    Mircea
  1. Copy- second point of displacement problem
    By Grand Pre in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Sep 2011, 07:33 pm
  2. distance in paperspace - command distance
    By flopo in forum AutoCAD General
    Last Post: 20th Jul 2011, 06:41 pm
  3. Replies: 14
    Last Post: 23rd Jul 2010, 05:14 pm
  4. Copying/Pasting with a displacement
    By matt4 in forum AutoCAD Beginners' Area
    Last Post: 13th Apr 2009, 07:10 pm
  5. displacement
    By rupert_valero in forum AutoCAD General
    Last Post: 4th Dec 2006, 04:06 pm
