Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 45
    Junior Member
    jafooli's Computer Details
    win 7
    Manufacture
    jafooli's Discipline Details
    foam fabrication
    Manufacture
    manufacturing
    AutoCAD LT 2004
    Feb 2012
    22
    Default how to make a spline to a polyline
    hi guys, im really new at autocad. Im using autocad lt 2004. My plotter does not recognise splines, and I would like to convert them to a polyline. can anyone tell me how to do this, been trying to do if for a few days now but to no good. All info appreciated
    when I highlight the spline it will not give me a option to turn the spline into a pline
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Please check the FLATTEN command (hope is available in LT).
    Regards,
    Mircea
    Junior Member
    win 7
    Manufacture
    foam fabrication
    Manufacture
    manufacturing
    AutoCAD LT 2004
    Feb 2012
    22
    FLATTEN is a unknown command is there another way? thanks for your help
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Found out that it is part of Express pack, so not available on AutoCAD LT. Sorry.
    Regards,
    Mircea
  5. #5
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    P e d i t ...
  6. #6
    Junior Member
    win 7
    Manufacture
    foam fabrication
    Manufacture
    manufacturing
    AutoCAD LT 2004
    Feb 2012
    22
    when I use command pedit, and click on the spline it says " object selected is not a polyline"
    is there anyother way?
  7. #7
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,455
    Save out as AutoCAD R12/LT2 DXF (*.dxf) then re-open.
  8. #8
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    OK, I see that spline editing didn't get improved until sometime after 2005....
  9. #9
    Junior Member
    win 7
    Manufacture
    foam fabrication
    Manufacture
    manufacturing
    AutoCAD LT 2004
    Feb 2012
    22
    right ok so ive sussed it, thanks guys, save as r12 format, open again. copy item, paste item as block on new sheet, this allows me to make the lines into polylines, great, now ive got it sorted, just to find out that the lines on my dxf are to tight for the knife cutter to cut too, if its not one thing its another... Thanks for all your help
  10. #10
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    If you post the drawing, or better yet, wblock out the splines to a new drawing and post that, someone here can use PEDIT in a newer version of AutoCAD to convert them directly, you just have to indicate how much precision you need.
    In the picture below, the top object is a Spline, then the spline converted to a pline with a "precision" of 10, then precision 1, then precision 99
  1. spline / polyline
    By td88 in forum AutoCAD Beginners' Area
    Last Post: 31st Aug 2011, 11:15 am
  2. Possible to draw 2 spline and make them as a whole?
    By resting in forum 3D Modelling
    Last Post: 28th Feb 2010, 05:54 pm
  3. make spline flatten
    By omid_221 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th May 2009, 11:54 am
  4. Spline to Polyline
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 13th Mar 2009, 10:10 pm
  5. Make objects along a spline or arc?
    By Kemion in forum AutoCAD General
    Last Post: 18th Jan 2008, 06:20 pm
