I wouldn't worry about the actual connector unless you're trying to produce 100% fabrication drawings, scheduled and all. Are you using a standard louvered lay-in ceiling diffuser with a round neck? If so, usually low pressure duct runs use "flex duct" for the last 5 feet of tie-in.
