Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 45
  1. #11
    Full Member myself's Avatar
    AutoCAD 2009
    Jun 2008
    Portugal - Porto
    97
    Another question…. When im drawing a pipe on Autocad MEP, if the size is smaller tha 200, it only shows a line instead of the real size of the pipe, however if i turn the size bigger than 200, the pipe shows up with all the fittings…. Is there a way to change this?
  2. #12
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,488
    Go to Style Manager > Piping Objects > Pipe System Definitions. Click on the pipe system you're working with, then on the right pane, click the "Single Line Graphics" tab. Uncheck both display settings to always show double lined linework.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  3. #13
    AutoCAD 2009
    Jun 2008
    Portugal - Porto
    97
    Thank you very much, that help you gave me with the piping size worked just fine.
    Now I am trying to figure out how can I set a system to use a specific duct fitting, for instance,I would like to set the short radius elbow for all my duct systems, however by default they are set to medium, which turns out to be annoying having to change them all the time.
    Any help on this particular case?
    By the way,I am using the project navigator that you had mentioned before, it’s veryuseful, even because I can work on separate parts of the project and then join them all on a view, making it easier and lighter to work.
    there's no need to answer my question about the duct fittings, i've figured out where i could change that option.
    Last edited by myself; 1st Mar 2012 at 04:05 pm. Reason: i've figured out the way to change the default duct fitting....
  4. #14
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,488
    Glad to see you are utilizing the Project Navigator. Many people overlook how great of a tool this really is.
    And to answer your question, type DUCTPREFERENCES at the command line. Go to the Parts tab. This is how you control your "preset parts" for each duct object. Also, be sure to browse the other tabs, setting your flex types, vanes/no vanes, duct lining/insulation, automatic text labels, and default duct routing settings.
    FYI, put the Flex Duct segment mode to the 3rd icon, "spline", and never change it. BIG time saver and it just works far better than any of the other two flex duct settings. Took me a long time to figure that one out, lol.
  5. #15
    AutoCAD 2009
    Jun 2008
    Portugal - Porto
    97
    Hello there, just anotherquestion.... how do i plug a duct that doesn’t connect to any other, forinstance, i have a duct with branches coming out, and then the main duct is pluggedat the end, not connecting to anywhere. I want to select a piece to plug it.
    Did I express myself in theway you could understand
  6. #16
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,488
    Simple. When you add a fitting, use the Endcap Fitting from the default catalog.
  7. #17
    AutoCAD 2009
    Jun 2008
    Portugal - Porto
    97
    Here is another question sent to the table for anyone to answer. Probably more directly to Stykface, who taught me about the project navigator.
    Which criteria do you have to create a new construct file on project navigator? Do you split the project by system’s, rooms or specific area of the building? I've done a quite complex central station that now has some pipes leaving to the room next to this one,that one is also quite complex with all the valves and pumps, not mention the three chillers, so i thought that i could create a new construction file to this new space. Once then i have a view file where i join all the elements to create a single model of the building. What do you think? I know that i shouldn’t split systems for more than a file, but then which rule should i follow,because having a system per construction file may turn more difficult to coordinate a space with many systems.
    Once again, I understand if you don’t get what I mean… just writing while thinking about my problem.
  8. #18
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,488
    I get what you mean, but this is something you'll have to answer yourself. There's no "right way" to do it, you'll just have to assess the job for yourself and choose what route works best for you.
  9. #19
    AutoCAD 2009
    Jun 2008
    Portugal - Porto
    97
    The 3D is going well and the engineer is pretty excited with what i have done so far.Until now i have been working on my laptop, which is pretty good and is giving me no problems at all, for you to have an idea, here it goes the main characteristics of my machine:
    - CPU: I7-720QM
    - VGA: ATI Mobility Radeon HD 5730 VRAM: 1GB
    -Memory: 4GB
    -16.0” HD/LED – plus a 19” monitor connected tothe laptop
    Saying this, i had to mention the engineer my laptop is good but a desktop with a good capacity would be necessary further on the model, I don’t know if this is your opinion or not, that’s why I came here to ask you all. However he gave me the answer I was willing to hear, write on paper the computer you think necessary to accomplish the model and we will find a way to bring it to you.
    And this yes, it’s what this thread is all about… which computer do you think would be nice, I don’t want anything over the limits, just one decent machine to have the job done. The crises in Portugal is pretty bad as you know and i dont want to give a wrong signal to my colleagues, asking for a expensive machine on difficult moments like this we are going through.
  10. #20
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,488
    Honestly, your machine is plenty capable if you max out the RAM. Anything more than the computer you currently have (with added RAM) will give you only a moderate increase in overall performance to be honest.
    But if you must, just remember bigger is better. Processor, RAM, and Video Card all come into play. RAM should be maxed out no matter what, especially since RAM is so freaking cheap right now. Core i7 Sandy Bridge is the best processor to get, and search on Autodesk's certified hardware list for the best video card your budget will allow.
  1. Replies: 0
    Last Post: 24th Mar 2011, 12:30 pm
  2. Replies: 0
  3. one seat - two installations
    By fle in forum Software & Licensing
    Last Post: 10th Aug 2010, 03:00 am
  4. Get AutoCAD installations on workstation in VBA
    By MSasu in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2010, 01:10 pm
  5. HVAC...
    By Dave-CSMW in forum AutoCAD Drawing Management & Output
    Last Post: 26th Sep 2009, 01:10 pm
