Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,297
    I really must be in the dark on this. I need a way to list all the blocks that are related to this drawing. The model space is empty...nothing is drawn in it at the moment. But the AutoCAD drawing file contains all these block references that are unique to this drawings and that is what I need a list of. Lee-Mac's program looked like it was going to do the trick but when I ran it, it only listed three blocks, which are the title blocks on the layout pages, so it's only listing the blocks which are in use.
    If I type the command "block" it brings up a menu which contains a drop down list which shows all the blocks currently saved in this drawing. I want to make a listing of these to see what I have or more important, what I don't have saved in this drawing for now.
    It's deja vu, all over again.
  2. #12
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    Have you tried the keyboard method of listing blocks?
    -b (enter)
    ? (enter) (enter)
    and there is your list of blocks in the drawing
  3. #13
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,297
    Thanks, that at least gets me a list of all the user blocks related to this drawing file, there are 147 of them and I'm not done yet. The method of listing is actually like this:
    -b <enter>
    ? <enter>
    * <enter>
    This listed all the blocks but unfortunately it does not list the description field which I so painstakingly field out each time I created or added a block to this file. Many of the block names are from this client's library and have only cryptic names like T1 or A-33, which tells me nothing about what it is.
  4. #14
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    Quote Originally Posted by Bill Tillman View Post
    -b <enter>
    ? <enter>
    * <enter>
    If you carefully examine the type of brackets on the prompt line, when you see [?], you have to enter the character in the bracket, but when you see <*>, that is the default setting for that prompt, and you only need to press Enter to activate it.
    Perhaps your version of AutoCAD gives different brackets
    Command: -b
    -BLOCK
    Enter block name or [?]: ?
    Enter block(s) to list <*>:
    Defined blocks.
  5. #15
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,501
    Quote Originally Posted by mdbdesign View Post
    Try Lee tool:
    http://www.lee-mac.com/blockcounter.html
    (I am not on commision)
    Haha! Thanks Marek
    As you've probably guessed by now, BCount, DataExtraction and my program will count Block References (i.e. those that are inserted in the drawing), not Block Definitions.
    To see what Definitions exist in a drawing, Elson has provided a method using the -Block command.
    Here is another quickly written LISP snippet:
    Code:
    (defun c:listblocks ( / a )
        (while (setq a (tblnext "BLOCK" (null a)))
            (print (cdr (assoc 2 a)))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  1. List of blocks??
    By AQucsaiJr in forum AutoCAD General
    Last Post: 13th Aug 2010, 03:27 pm
  2. list blocks in drawing
    By redgar in forum AutoCAD Beginners' Area
    Last Post: 22nd Apr 2009, 07:12 am
  3. List of Blocks
    By Designer in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Mar 2008, 07:58 pm
  4. List and/or display all BLOCKS in an open drawing.
    By JimWebster in forum AutoCAD Drawing Management & Output
    Last Post: 14th Mar 2005, 11:05 pm
  5. List all blocks in a drawing (database?)
    By vldazzle in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Oct 2004, 05:16 pm
