+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Full Member Grenco's Avatar
    Computer Details
    Grenco's Computer Details
    Operating System:
    Vista
    Computer:
    Dell Precision T3400
    Using
    AutoCAD 2010
    Join Date
    Jan 2009
    Location
    Den Bosch, Holland
    Posts
    74
    Question VBA - How to edit in a not active layout
    Hello all, long time no see...
    I got a small problem.
    I've got a "template"-layout called Basis. This is a layout wich I want to copy and rename. So far so good.
    To copy:
    ThisDrawing.SendCommand "_layout" & vbCr & "C" & vbCr & "Basis" & vbCr & RSCheck.Fields("Object_ID") & vbCr
    (RSCheck.Fields... is a .mdb recordset wich contains the values I want to use, The Object_ID is the name of the new layout)
    Now I want to edit some attributes in the new copied layout.
    ThisDrawing.ActiveLayout = ThisDrawing.Layouts((RSCheck.Fields("Object_ID")))
    The layout I want to edit is now active and I'm able to edit everything I want.
    The problem is that I have to copy AND edit about 250 layouts. It's running a bit slow because I have to activate the layout. Is there a way in VBA to make changes in a layout without activating it?
    I hoped to use For Each Elem In ThisDrawing.Layouts(RSCheck.Fields("Object_ID")) but that doesnt work.
    Who can help me?
  2. #2
    Super Member fixo's Avatar
    Computer Details
    fixo's Computer Details
    Operating System:
    Windows 7
    Motherboard:
    E7500
    CPU:
    Intel(R)Core(TM)2 DUO CPU 2.93HGz
    RAM:
    4098 Gb
    Graphics:
    1024 Gb
    Using
    AutoCAD 2009
    Join Date
    Jul 2005
    Location
    Pietari, Venäjä
    Posts
    1,587
    Default
    You can try to edit non activelayout like this
    Code:
    Dim actSpace as acadblock
    Set actSpace=thisdrawing.layouts("Object_ID").Block
    'then you can to do your things in there directly, eg.:
    Code:
    actspace.addline(p1,p2)
    actspace.addcircle(p3, radius) ETC...
    ~'J'~
    The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
  3. #3
    Computer Details
    Operating System:
    Vista
    Computer:
    Using
    AutoCAD 2010
    Join Date
    Jan 2009
    Location
    Den Bosch, Holland
    Posts
    74
    Default
    Thank you for your reply Fixo!
    actspace.add** is all about adding lines or other elements.
    But how can I read all the elements and modify that are inside of the copied layout?
    I want to modify a block with attributes in the layout called "KADER"
  4. #4
    Computer Details
    Operating System:
    Windows 7
    Motherboard:
    E7500
    CPU:
    RAM:
    4098 Gb
    Graphics:
    1024 Gb
    Using
    AutoCAD 2009
    Join Date
    Jul 2005
    Location
    Pietari, Venäjä
    Posts
    1,587
    Default
    Something like this may helps, change to your suit:
    Code:
    Dim ent as acadentity
    Dim blkref as acadblockreference
    for each ent in actspace
    if typeof ent is acadblockreference then
    set blkref=ent
    if blkref.Effectivename="KADER" then
    dim atts as variant
    dim att as attributereference
    atts= blkref.getattributes
    for each att in atts
    if att.tagstring="MYTAG" then
    att.textstring="MYVALUE"
    exit for
    end if
    next att
    end if
    end if
    next ent
    ~'J'~
  5. #5
    Computer Details
    Operating System:
    Vista
    Computer:
    Using
    AutoCAD 2010
    Join Date
    Jan 2009
    Location
    Den Bosch, Holland
    Posts
    74
    Default
    You are the best!!
  6. #6
    Computer Details
    Operating System:
    Windows 7
    Motherboard:
    E7500
    CPU:
    RAM:
    4098 Gb
    Graphics:
    1024 Gb
    Using
    AutoCAD 2009
    Join Date
    Jul 2005
    Location
    Pietari, Venäjä
    Posts
    1,587
    Default
    Glad I could help
    Cheers
    ~'J'~
  7. #7
    Computer Details
    Operating System:
    Vista
    Computer:
    Using
    AutoCAD 2010
    Join Date
    Jan 2009
    Location
    Den Bosch, Holland
    Posts
    74
    Default
    Because I want to improve the perfomance..... How can I replace this slow command:
    Code:
    Is there a better way to copy a layout without using .SendCommand?
  8. #8
    Computer Details
    Operating System:
    Windows 7
    Motherboard:
    E7500
    CPU:
    RAM:
    4098 Gb
    Graphics:
    1024 Gb
    Using
    AutoCAD 2009
    Join Date
    Jul 2005
    Location
    Pietari, Venäjä
    Posts
    1,587
    Default
    Not tried but maube CopyObjects method may helps
    Just an idea
  9. #9
    Computer Details
    Operating System:
    Windows 7
    Motherboard:
    E7500
    CPU:
    RAM:
    4098 Gb
    Graphics:
    1024 Gb
    Using
    AutoCAD 2009
    Join Date
    Jul 2005
    Location
    Pietari, Venäjä
    Posts
    1,587
    Default
    Quote Originally Posted by Grenco View Post
    Code:
    Try this way that I mentioned earlier
    Code:
    Option Explicit
    Public Sub CopyFromLayout()
        Dim oLayoutCopy As AcadLayout
        Dim oLayout As AcadLayout
        Dim objCollection() As Object
        Dim n
        Set oLayoutCopy = ThisDrawing.Layouts.Add("MyNewLayoutName") ' <---> 'ThisDrawing.Layouts.Add(RSCheck.Fields ("Object_ID"))
        Set oLayout = ThisDrawing.Layouts.Item("Basis")
        ThisDrawing.ActiveLayout = oLayoutCopy '<-- for the fast work
        With oLayout.Block
            If .count > 0 Then
            ReDim objCollection(0 To .count - 1)
            For n = 0 To .count - 1
                Set objCollection(n) = .Item(n)
            Next
            ThisDrawing.CopyObjects objCollection, oLayoutCopy.Block
        End If
       End With
       oLayoutCopy.CopyFrom oLayout '<-- to copy other things from "Basis": plot settings, etc
    End Sub
    ~'J'~
Similar Threads
  1. text edit in layout - problem
    By flopo in forum AutoCAD General
    Last Post: 3rd Mar 2011, 09:11 am
  2. layout lisp (help with edit)
    By lutcus in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Sep 2010, 10:02 pm
  3. Edit Table Layout
    By Bill Tillman in forum AutoCAD General
    Last Post: 14th Aug 2009, 12:08 am
  4. VB.Net question - active viewport in a layout
    By Tipo166 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Apr 2009, 03:56 pm
  5. Edit Layout Template Block Information
    By cbpack51 in forum AutoCAD Drawing Management & Output
    Last Post: 27th Mar 2009, 03:57 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
