Results 1 to 5 of 5
Thread: Mass Properties
    Full Member WERDNA's Avatar
    Structural
    WERDNA's Discipline Details
    Structural Designer
    Structural
    AutoCAD 2010
    Feb 2012
    Scotland
    57
    Default Mass Properties
    Hi,
    Can anyone tell me how to determine the mass properties of bolt, refer to attached image.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,991
    I'm afraid that your image isn't visible - please check this tutorial for image attachment procedure.
    Regarding the calculation of volume, seems that since you are using LT the 3D modeling and MASSPROP command are out of question; you will have to calculate the volume by hand and multiply it with the density of material. If you will manage to attach the image, maybe someone with full AutoCAD will find the time to help you.
    Regards,
    Mircea
    Structural
    Structural Designer
    Structural
    AutoCAD 2010
    Feb 2012
    Scotland
    57
    File attached this time, maybe mass properties is not the right description, it is the second moment of area in particular that I am after?
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,991
    This is the result for your shape:
    Code:
    Area:                    428.8445
    Perimeter:               74.3788
    Bounding box:         X: -10.5000  --  10.5000
                          Y: -12.0000  --  12.0000
    Centroid:             X: 0.0000
                          Y: 0.0000
    Moments of inertia:   X: 16124.6459
                          Y: 13379.6690
    Product of inertia:  XY: 0.0000
    Radii of gyration:    X: 6.1319
                          Y: 5.5856
    Principal moments and X-Y directions about centroid:
                          I: 13379.6690 along [0.0000 1.0000]
                          J: 16124.6459 along [-1.0000 0.0000]
    Regards,
    Mircea
  5. #5
    Structural
    Structural Designer
    Structural
    AutoCAD 2010
    Feb 2012
    Scotland
    57
    Thanks Mircea
  1. Can't find Mass Properties of a Solid Model.
    By jbird68 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Aug 2010, 08:19 pm
  2. Mass & Volume Properties in AutoCad 2009
    By kingjim9 in forum AutoCAD General
    Last Post: 30th Dec 2009, 12:39 am
  3. Confusing Mass Properties
    By marcusdarcy in forum Autodesk Inventor
    Last Post: 4th Dec 2009, 03:25 pm
  4. Mass-dimensioning
    By dlions78 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Nov 2008, 02:26 am
  5. Mass Properties
    By FungShui in forum AutoCAD Drawing Management & Output
    Last Post: 14th Sep 2006, 11:31 pm
