Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Super Member
    not specified
    Feb 2006
    705
    So install ObjectARX 2010 on both machines and use it?
    Not the ObjectARX 2010 package.
    Thank you,
  2. #12
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    I’m not exactly sure what the distinction is between “ObjectARX 2010” and “ObjectARX 2010 package”. Nor am I sure how SharpDevelop compares with Visual Studio; I have only used VS.
    Your situation sounds rather unique. Due to limitations on what can and can’t loaded on a work machine, you are forced to use a roving development setup (Probably a tricky process that does not benefit from well documented procedures). Once you sort this all out you may become the resident expert on multi-machine policy-IDE-AutoCAD 32/64bit version- setups.
    Can you install ObjectARX_2010_Win_64_and_32Bit.exe on to the USB drive along side SharpDevelop? If so then setting the reference to point at USBDrive\ObjectARX 2010\inc may solve the issue rather nicely.
  3. #13
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    muck - I shared this with you (once?) before:
    Quote Originally Posted by RenderMan View Post
    <snip>
    Thinking more long-term, consider porting your code to VB.NET - You'll need Visual Studio 2010 (I use Express), the appropriate ObjectARX SDK(s), and I recommend you also use the current Wizard for properly debugging (when using Express).
    FWIW - I have no issues working on projects between Windows 7 32-Bit (home) & 64-Bit (work), especially when using Visual Studio Tools for Office (VSTO), given that I have full VS at home, and only Express on my work laptop.
    HTH
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  4. #14
    Super Member
    not specified
    Feb 2006
    705
    Well I got Sharp to run but it is giving the error
    "Project is configured as dll and no excution command is
    Specified". You can specify and execution command in
    project options?
    May be a question for Sharp Dev Forum.
    I would still like to get Sharp to work.
    Thank you,
  5. #15
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    You must define a command when writing your dll. Try using this to define your command:
    Code:
    Imports Autodesk.AutoCAD.Runtime
    Public Class muckClass
        'Define the command 'muckCommand'
        <CommandMethod("muckCommand")> _
        Public Sub muckCommand()
             MsgBox("muckCommand")
             ' Type your code for the command here
        End Sub
    End Class
    Use 'netload' to load your dll and then type 'muckCommand' to get your new command to work. Don't forget you can't unload the dll, you have to restart AutoCAD.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
  1. Rolling out new CAD machines.
    By Glen1980 in forum CAD Management
    Last Post: 5th Jan 2012, 09:31 am
  2. MEP Catalog for other machines
    By waydawn in forum MEP
    Last Post: 16th Jun 2010, 05:54 pm
  3. portable cad?
    By michaeloureiro in forum AutoCAD General
    Last Post: 27th May 2008, 02:11 pm
  4. CAD Machines
    By watzmann in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jan 2007, 09:22 pm
