Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2012
    Mar 2012
    1
    Default Plotting Viewport 2
    I have created a customised paper size in page setup (3000X900mm); the viewport is a clipped polygon which was chosen as I wished to create a small legend in the bottom corner.
    Although the drawing has only 1 viewport, when I attempt to plot, the console reads "plotting viewport 2" and nothing actually plots. The plotter is working fine for other drawings. Any ideas what might be wrong?
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    If you didn’t explicitly disabled it, there will be a new viewport in each new layout (Options -> Display -> Layout elements -> Create viewport in new layouts). So, probably there is another viewport below the one that you just added. Chances are that the contours of this viewport are on drawing area’s edges, so not easily visible; to check this do a zoom extends and chose View -> Zoom -> Out from menu to investigate.
    Regards,
    Mircea
  1. Plotting Viewport
    By Captnkirk in forum AutoCAD Drawing Management & Output
    Last Post: 15th Aug 2011, 05:47 pm
  2. Only initial viewport is plotting
    By browen in forum AutoCAD Drawing Management & Output
    Last Post: 5th Apr 2011, 01:31 pm
  3. Viewport and plotting issues with scale
    By lil_d in forum AutoCAD Drawing Management & Output
    Last Post: 30th Sep 2010, 08:40 am
  4. Viewport override bug when plotting
    By spittle in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Dec 2008, 05:25 pm
Tags for this Thread
