+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    6,051
    Default DWG True View reads Viewbase generated drawings.
    I am a big fan of the Viewbase functionality introduced in Autocad 2012, (which has subsequently been greatly improved in Autocad 2013) but was disappointed the first time I excitedly sent a Viewbase generated drawing to a coworker on an earlier version of Autocad, as she was unable to read it. I just figured out, that as long as recipients have downloaded the latest version of the free DWG True View software from Autodesk they will be able to read Viewbase images.
    I have erroneously warned in a number of posts on the forum that those without Autocad 2012 would be out of the loop, should they receive drawings generated with this functionality, due to the lack of retro-compatability. Fortunately, I was only half right, just make sure that all recipients have downloaded the latest free version of DWG True View, and all will be good in the 'hood.
    Now that Autocad 2013 has been released, bear in mind that the default file format is new for 2013, and that earlier versions will not be able to open files which have not been saved to earlier compatible file types.
    DWG True View 2013 will enable, as previously stated regarding DWG True View 2012 recipients to open and read drawings in file type 2013.
    If you receive such files without Autocad 2013, you can open them in DWG True View 2013. Should you want to you can then save them to another earlier file type, although the VIEWBASE functionality will not survive the transition to the earlier version.
    Volume and repetition do not validate opinions forged in the absence of thought.
  2. #2
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    12,108
    Default
    No problem, I will order my superiors to download Dwg Trueview immediately.
  3. #3
    Computer Details
    Operating System:
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    RAM:
    8 GB RAM
    Graphics:
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    12,108
    Default
    Are you hiring I now need a new job?
  4. #4
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    Posts
    6,051
    Default
    Quote Originally Posted by SLW210 View Post
    If you're like me and work with 3D Models most of the time, then I assume you mean you will be looking for one or two new jobs just to fill up your workday, since your productivity just went up by about 800%. If you think that your bosses had a negative reaction to the suggestion that they (or you, or the IT guy) spend 3 minutes downloading the free DWG TRUE VIEW 2012 add-on, then watch how they react when you suggest that every workstation and every contact with whom you work needs to be upgraded to Autocad 2012, in order that you can be that much more competitive in the market, and they should foot the bill!
  5. #5
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    Posts
    6,051
    Default
    HIRING? Hell, I may have just redunced myself!
Similar Threads
  1. AutoCAD 2012 ViewBase command
    By ReMark in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Sep 2012, 12:09 am
  2. Acad 2012: Viewbase command?
    By 43st in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Nov 2011, 12:29 pm
  3. 2012 Civil 3D stuff doesn't show up in older versions
    By clepine in forum Civil 3D & LDD
    Last Post: 1st Aug 2011, 04:08 pm
  4. how to make my 2009 looks like older versions (older style)
    By nbaryosef in forum AutoCAD General
    Last Post: 24th Oct 2008, 03:06 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
