Tube/Pipe Run?
DoctorDrake
Having trouble figuring out how to draw 90's and 45's using just inventor (not professional.) I am trying to draw a drain on a vertical seperator. The drain is 5 inches long and makes a 90 degree bend sideways. the radius of the bend is 4 3/16" (4.1875".) drain bend.jpg i have attached the autocad dwg of what i am trying to accomplish. thank you for your help
  • 5 months later...
Did you ever find a solution for this? I am also wondering how to do it in Inventor without Inventor Professional. I can do it in AutoCAD using offset in 2D or revolve and union in 3D but I'd like to learn how to do it in Inventor.
For now I just drew it in ACAD and imported it into Inventor.
Do you still need to know how to do it the easy way (in Inventor)?
drain 90.ipt
This is the easy way to do it in Inventor.
Or at least, it's an easy way. You'll have to change the position of the circles - I don't think the alignment is quite the way you wanted, but the principle is the same.
  • 3 weeks later...
