+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Forum Newbie
    Using
    Inventor 2012
    Join Date
    Mar 2012
    Posts
    8
    Default why the file igs imported to inventor cannot do stress analysis
    Hi all,
    i'm newbie in inventor. i had got this skull model in .igs format. then i imported to inventor version 2012 with option in single composite features. so now i guess the skull model is in one part.
    Q1: however the model still in transparent which im not sure if this will affect what im going to do in stress analysis. how do i fix the transparent model?
    Q2: i try to repair the model by entering the repair mode. i manage to find those errors but i cant repair using 'heal errors' button. n i tried to stitch also wont work. how do i repair this model?
    this is the errors shown:
    Q3: eventually i wanted to do stress analysis for my skull model. i can assign materials but other steps like constraints, load, are unable to to select the surface that i want to do simulation. it just cant click on the surface which i dunno why. how do i solve this prob & can proceed to the stress analysis?
    Hope you guys can help me out as this is my final year project for my bachelor degree. I really in need of these solutions. Please help me!!
    Thousands thanks in advanced!!!!
  2. #2
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    7,007
    Default
    You have a surface model - not a solid model.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  3. #3
    Forum Newbie
    Using
    Inventor 2012
    Join Date
    Mar 2012
    Posts
    8
    Default
    then how do i change to solid model?
  4. #4
    Junior Member
    Computer Details
    Mister Blonde's Computer Details
    Operating System:
    Windows 7 64-bit
    CPU:
    i7-2600K CPU @ 3.40 GHz
    RAM:
    20 GB RAM
    Graphics:
    ATI FirePro V7750
    Primary Storage:
    1 TB
    Monitor:
    24" VA24448, 22" Acer V223W
    Discipline
    Manufacture
    Mister Blonde's Discipline Details
    Occupation
    Design Engineer, Industrial Electronic Manufacturer
    Discipline
    Manufacture
    Using
    Inventor 2013
    Join Date
    Feb 2012
    Location
    Temecula, CA
    Posts
    20
    Default
    I am having the same problem with the transparent part, and they are indeed surface models. You can use the stitch feature to stitch together two surfaces, however this will not work for my part. I am not sure of any other ways to create a solid from surface components. Any one else have better ideas?
  5. #5
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    7,007
    Default
    Attach your original file here.
  6. #6
    Junior Member
    Computer Details
    Operating System:
    Windows 7 64-bit
    CPU:
    RAM:
    20 GB RAM
    Graphics:
    ATI FirePro V7750
    Primary Storage:
    1 TB
    Monitor:
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Using
    Inventor 2013
    Join Date
    Feb 2012
    Location
    Temecula, CA
    Posts
    20
    Default
    I don't know if you meant me or not JD, but I have attached my files. The problem I am having with this part and many others is the importing a dwg into inventor. If you have any advice, or know of some good resources that would be very appreciated.
    Thank You
  7. #7
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    7,007
    Default
    You will have to learn the Construction or Repair environments.
    This one is trivially easy to get to solids as there isn't anything wrong with the original geometry.
  8. #8
    Junior Member
    Computer Details
    Operating System:
    Windows 7 64-bit
    CPU:
    RAM:
    20 GB RAM
    Graphics:
    ATI FirePro V7750
    Primary Storage:
    1 TB
    Monitor:
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Using
    Inventor 2013
    Join Date
    Feb 2012
    Location
    Temecula, CA
    Posts
    20
    Default
    OK, thank you very much for your help, I will try learning more about the repair environments. I am new to Inventor so I am trying to learn as much as I can. Thanks again
  9. #9
    Forum Newbie
    Using
    Inventor 2012
    Join Date
    Mar 2012
    Posts
    8
    Default
    now that i successfully convert it to solid model. but this intersecting face drive me crazy. i tried all the repair methods but it just doesnt work. mind helping??
  10. #10
    Junior Member
    Computer Details
    Operating System:
    Windows 7 64-bit
    CPU:
    RAM:
    20 GB RAM
    Graphics:
    ATI FirePro V7750
    Primary Storage:
    1 TB
    Monitor:
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Using
    Inventor 2013
    Join Date
    Feb 2012
    Location
    Temecula, CA
    Posts
    20
    Default
    Attach your file, then people will be able to take a better look at it.
Similar Threads
  1. Help in stress analysis
    By gattuso in forum Autodesk Inventor
    Last Post: 17th Feb 2011, 08:32 am
  2. Replies: 0
    Last Post: 15th Nov 2010, 08:30 am
  3. Stress Analysis Help
    By mingyar in forum Autodesk Inventor
    Last Post: 16th Mar 2010, 01:41 pm
  4. stress analysis
    By prasanth14026 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Mar 2010, 12:32 pm
  5. Stress Analysis
    By Gno in forum Autodesk Inventor
    Last Post: 21st Sep 2009, 02:42 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
