Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Junior Member
    not specified
    Jul 2005
    15
    Default Editting two items at once..??
    If I draw an item, and then copy it numerous times within the same drawing, is there a way of editting the first one drawn and having the copies of this item automatically update with the changes?? The only way i can think of is with the block command, but this would mean keep exploding, editting and redefining the block to update the duplicates. IS there any other way to do this?? Using autocad 2000, all in model space. thanks
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    If it's something you anticipate editing multiple times, consider keeping it a separate file, and xref into the main drawing.
    Junior Member
    not specified
    Jul 2005
    15
    I ruled that out as it would take too long, the reason being there are about 24 items in the drawing that i would like to duplicate, but only have to edit one instance of. Any internal ref commands that would do it?
    Senior Member
    not specified
    Feb 2006
    Guelph, Ontario
    436
    I would suggest making it a block...copy it however many times that you want and then use the "REFEDIT" command to edit the entity to whatever you want.
    Mike
  5. #5
    Junior Member
    not specified
    Jul 2005
    15
    if you create a block of the original item, then copy that numerous times. To edit the original you obviously have to explode that. to update the copies you you have to convert the exploded original back to the block again saying yes to the re-defining part. I've not used the REFEDIT command before....how does that help, and prevent having to keep doing what i've said above using the BLOCK command?
  6. #6
    Senior Member
    not specified
    Feb 2006
    Guelph, Ontario
    436
    the REFEDIT command allows you to edit the block from within the drawing file without exploding it. Type in "REFEDIT" then it prompts you to select a block to edit. Once you select your block you do whatever you want to is and then you type in "REFCLOSE" select save and it will update all of the blocks with that same name in your drawing.
    Mike
  7. #7
    Full Member cadkiwi's Avatar
    cadkiwi's Computer Details
    Manual Drafting Machine..lol
    Multi-disciplinary
    cadkiwi's Discipline Details
    Building Services Electrical Draftsperson
    Multi-disciplinary
    Building Services / Roading
    not specified
    Apr 2006
    Auckland, New Zealand
    26
    Default "REFEDIT"
    I have ACAD2005 and "REFEDIT" is an unknown command...what do you use in ACAD2005??????????
    Fail to Plan, Plan to Fail.
  8. #8
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,245
    You must be using 2005LT. Refedit has been around since acad2000. It's only available in the full version though.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    not specified
    Apr 2006
    26
    Default "REFEDIT"
    I have the full version!
    It seems I need to use a "-" first, as in:
    "-refedit "
    Thanks!
  10. #10
    Senior Member Ako's Avatar
    AutoCAD 2007
    Mar 2006
    Warrington UK
    309
    Strange! entering a dash before the command usually forces command line usage. REFEDIT works in 2004. Have they changed it in 2005?
    Dave
