Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2008
    Mar 2012
    2
    Default extrude and sweep command
    hi there...i have a question, what is the difference between extrude and sweep command in terms of extruding a close polyline using a path?
    AutoCAD 2013
    Nov 2011
    6,045
    I believe that there is little to no difference between the two commands, within the context of using them along a path, and that they will yield the same results.
    Forum Newbie
    AutoCAD 2008
    Mar 2012
    2
    thanks, but can you be more specific? or can you explain it, its highly appreciated.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    One difference is that SWEEP command will automatically align the contour to the path.
    Regards,
    Mircea
  5. #5
    AutoCAD 2013
    Nov 2011
    6,045
    Quote Originally Posted by cadtagz View Post
    Typically I would characterize the EXTRUDE command as being used for pure geometric shapes, or linear enlargement. SWEEP is usually used for the generation of more complex non rectilinear shapes. There is another command PRESSPULL which is even easier to use than EXTRUDE, because it will work on a greater variety of object types, and they do not need to be closed in order to create 3d Solids. If you investigate your MODELING and SOLID EDITING toolbars or palettes you will find other available options.
  1. Modeling a leadscrew - loft, sweep, extrude, helix - no luck.
    By -TJ in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Nov 2012, 04:57 pm
  2. Help!! 3D Extrude or Sweep -- Glass block out in Concrete -- Complex Path
    By knight3252 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th May 2011, 08:38 pm
  3. how to use sweep command in 3D
    By srinu_vasu38 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Apr 2010, 01:13 pm
  4. Extrude or Sweep?
    By Oxygen454 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 28th Dec 2009, 07:29 am
  5. Sweep or extrude
    By lilrose in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Jan 2009, 02:09 pm
