kvrle Posted March 8, 2012 Share Posted March 8, 2012 Hello, I have polyline (created from line and arc). I want to create new point/line on this polyline with input lenghts. I found function divide which splits polyline on equal lenghts. I don't want that. I want split polyline on different lenghts. I have axis wich represent road. I must create stationary on different lenght. TNX Quote Link to comment Share on other sites More sharing options...
MSasu Posted March 8, 2012 Share Posted March 8, 2012 Please check if the tool from this thread isn't useful for you. Also, welcome to the Forum, kvrle! Regards, Mircea Quote Link to comment Share on other sites More sharing options...
bill_borec Posted March 8, 2012 Share Posted March 8, 2012 You can use the command 'LEN' which stands for length and then use the option 'T' for total length, enter the length and select the line, the line will now be the exact length you designated. Quote Link to comment Share on other sites More sharing options...
kvrle Posted March 9, 2012 Author Share Posted March 9, 2012 Tnx for replies but still doesn't work. Measure and LEN function don't use arc for calculating. Both functions use only lines for object. Mistake on 3 km lenght is 6 m. It's too much. CopyAlongCurve function doesn't give results what I want. Any other solution? Quote Link to comment Share on other sites More sharing options...
nestly Posted March 9, 2012 Share Posted March 9, 2012 LENthen absolutely does work with arcs and polylines, I use it all the time. Create a copy of the polyline and then use LENthen starting from the end farthest from the measuring point. I also don't understand how COPYALONGCURVE wouldn't also work. Quote Link to comment Share on other sites More sharing options...
bill_borec Posted March 9, 2012 Share Posted March 9, 2012 Can you post a file that shows the 6m error? LEN measures the length along the polyline, even through curves. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 9, 2012 Share Posted March 9, 2012 Maybe just not using the right options Here's a video showing both LENgthen and COPYALONGCURVE.lisp The only thing those two methods don't do is actually split the polyline (path) into individual segments, but that's just a matter of placing an object at the measured points to break the polyline with. [url= ][/url] Quote Link to comment Share on other sites More sharing options...
kvrle Posted March 9, 2012 Author Share Posted March 9, 2012 It works!!! Tnx guys! I have new problem now I found mistake. The mistake wasn't in acad function. The mistake is in project which was made by designer TNX for help Quote Link to comment Share on other sites More sharing options...
