Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2012
    Mar 2012
    2
    Default Different horizonal and vertical scaling
    Hello newbie here,
    So my project is to design a sewer from elevation points we surveyed out in the field. So far I have created a polyline which represents the surface we surveyed. Our instructor gave us a template with a profile grid on the bottom half. I have place this polyline inside the grid but I am having trouble scaling this to the correct vertical and horizontal scales. I have made the polyline into a block. I know I can adjust the X and Y scaling of the block under properties--> geometry but I am confused about how to set these values correctly.
    I need a vertical scale of 1"=2' and a horizontal scale of 1"=20', I am just confused about what I should enter into the X and Y scale factors to give me the correct scaling. Any help at all is appreciated.
    Thanks
    Forum Newbie
    AutoCAD 2012
    Mar 2012
    2
    Also It needs to be printed on 26"x36" drafting paper if that matters at all.
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Don't scale it like that. Vanilla AutoCad is a right pain if you have a long section drawn at scale 1:1 in both the vertical and horizontal axes as you cannot scale a viewport on two different axes (vertical and horizontal). Making it a block and scaling the x & y individually should work if you simply have a polyline representing the natural surface (although you wouldn't want to scale an actual long section and all the levels associated with it).
    The best way I have found is to draw it not 1:1 scale (which is also the way a lot of the civil design programs will do it). I.e. you might have you horizontal axis on a 1:10 scale and then your vertical axis on a 1:20 axis (where if doing it manually in AutoCad you would just have to scale that yourself manually when drawing the long section).
    Civil
    Feb 2009
    2,338
    Quote Originally Posted by OrionTheHunter View Post
    Well work out how long the long section will be (i.e. 50m, 500m, 5km) and then what size horizontal scale will be needed to make it fit on the sheet. Then choose a nice rounded/standard scale for the vertical scale.
  5. #5
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    I don't work with Imperial units so I can't tell you how to do it, but this is what I do with this problem.
    1. In the end I should have the horizontal scale at 1:100 and the vertical scale at 1:400
    2. I scale the drawing in the viewport to 1:100 so I can draw the length of the pipes (in my case) at 1:1 scale in Model Space.
    3. First I draw pipes with a vertical scale of 1:1.
    4. I use BLOCK on the whole thing, and then scale the block only in Y (vertical direction) 4 times.
    5. I explode it, and then add my texts and misc.
    This process is helped by pre-made blocks for the text and levels and grid-lines that are already scaled so I know how it should look in the end so if I scale it wrong, the pipes won't fit with the premade blocks and I something is wrong.
    And yes, I wish I could use Civil 3D
    MTJIGSTRING = BAZINGA
  6. #6
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Core™ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2013
    Aug 2007
    Gloucester UK
    327
    If you still want to scale your block the x would be 1/240 (0.0041666) and the y would be 1/24 (0.041666). Assuming you are trying to manually draw it to scale in model space. The better way would be to scale your block with with a factor of 10 in the y direction (i.e. x=1, y=10) in model space then use a scale of 1" to 20' in the viewport in paperspace.
  1. Vertical Products
    By derockere in forum Vertical Products: General
    Last Post: 19th May 2011, 02:31 pm
  2. Horizonal Alignment Lisp Inquiry
    By runner214 in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Apr 2010, 08:50 am
  3. Vertical Text
    By CadNew in forum AutoCAD Beginners' Area
    Last Post: 13th Aug 2009, 12:16 am
  4. Vertical Curves
    By Jamalama in forum Tutorials & Tips'n'Tricks
    Last Post: 22nd Aug 2006, 01:33 pm
  5. vERTICAL TEXTURES
    By simonbratt99 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Sep 2005, 01:16 pm
Tags for this Thread
