Could you reshape it using the Grips?
Another option would be to create a new rectangular viewport and ditch the polygon.
How do I change a polygonal viewport to a rectangular viewport?
Make a new viewport, zoom and pan to approximate the scale and location, then use matchprop for the scale, line it up with osnaps on objects in MS, erase the polygonal vp.
Edit:
Correct answer is to use Vclip (Clip in 2012) and use Delete option, you can also get to this with right click shortcuts.
"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
If your right click context menu is enabled, select the viewport, right click, viewport clip, "D", enter.
Rob
Create a new rectangular viewport as like you want an then clip to previous viewport by the use vpclip command.....from this command your scale would be constant as well as your drawing....
keep hard working
