Mechanical Posted March 9, 2012 Share Posted March 9, 2012 Can someone tell me the most efficient way of inserting a title block (the border around a drawing with text etc) into a layout? Sometimes when I insert a title block it seems like the title block is too big or too small for the layout, any tips and help would be very welcome. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 10, 2012 Share Posted March 10, 2012 I don't know if it's the "most efficient" but I have a different titleblock for each size layout (paper) Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 10, 2012 Share Posted March 10, 2012 Yep, definitely the best way to go, and long term most efficient with the best result. Quote Link to comment Share on other sites More sharing options...
Mechanical Posted March 10, 2012 Author Share Posted March 10, 2012 This may seem like a dumb question but, can you tell me the process you use to insert a title block? (I use Insert->Block->Insert and then attach the dwg) can you tell me are you in paper space when you insert your titleblock in your layout? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 10, 2012 Share Posted March 10, 2012 There are those who put them in modelspace, but I put the sheet in paperspace, just makes more sense. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 10, 2012 Share Posted March 10, 2012 Get in the habit of using layouts, for title insert it at true size our A1 is 804x567 then plot at 1:1 use mview to create windows at scale of your model. Lots of posts about this under plotting. Like above different sheets different title sizes but always 1:1 Ps a A3 is a A1 plotted at 1:2 we do not resize the title sheet Quote Link to comment Share on other sites More sharing options...
nestly Posted March 10, 2012 Share Posted March 10, 2012 Insert the Titleblock in Paperspace. The title block should be just a bit smaller than the printable area of your paper. ie if you're printing on 8.5 x 11 paper, a titleblock that measures 8 x 10.25" would be appropriate. Quote Link to comment Share on other sites More sharing options...
Mechanical Posted March 11, 2012 Author Share Posted March 11, 2012 i would really like to know how do you scale a large title block to fit on the printable area in a layout(the rectangular dotted line)? Quote Link to comment Share on other sites More sharing options...
nestly Posted March 11, 2012 Share Posted March 11, 2012 (edited) Do you mean you want use a titleblock that's designed to fit on a larger paper? I hope not, because the detail is going to be too small to be usable. You should use or make a titleblock with dimensions that are just a bit smaller than the printable area (the dotted lines in the layout) Open the plot dialog box, select your printer/plotter, pick the paper size, then hover over the preview to see the printable area. Edited March 11, 2012 by nestly Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 11, 2012 Share Posted March 11, 2012 What units are you working in? We work in imperial units and with paper sizes ranging from 8.5x11, 11x17, 18x24 to 24x36 so we have titleblocks that are sized accordingly. Quote Link to comment Share on other sites More sharing options...
Mechanical Posted March 11, 2012 Author Share Posted March 11, 2012 ok, I am working with a title block that is slightly larger than the layout border, what is the correct method to shrink the block to fit the paper margin in the layout? Quote Link to comment Share on other sites More sharing options...
nestly Posted March 11, 2012 Share Posted March 11, 2012 ok, I am working with a title block that is slightly larger than the layout border, what is the correct method to shrink the block to fit the paper margin in the layout? Open the block with the block editor, and change the dimensions of the Titleblock border(s). Then save the block with a name that allows you to identify what size paper it's designed for. Alternately, if your titleblock is designed for a certain size paper, but your printer driver has an undersized printable area, you can just increase the size of the printable area in the plot dialog box Quote Link to comment Share on other sites More sharing options...
Mechanical Posted March 11, 2012 Author Share Posted March 11, 2012 Open the block with the block editor, and change the dimensions of the Titleblock border(s). Then save the block with a name that allows you to identify what size paper it's designed for. Alternately, if your titleblock is designed for a certain size paper, but your printer driver has an undersized printable area, you can just increase the size of the printable area in the plot dialog box Thanks for suggestions, do you know of any other method where I can make the titleblock slightly shrink or "fit to page" within the paper extents? I have seen someone at my old workplace do it but I cant remember the exact method? Quote Link to comment Share on other sites More sharing options...
nestly Posted March 11, 2012 Share Posted March 11, 2012 Can I ask why you don't just want to make the titleblock the correct size for the paper? I guess if you're bound and determined not to use a titleblock that's the proper size for the paper, you can use the SCALE command to make it a little bit smaller, but I wouldn't advise it, especially if the titleblock contains hash marks around the border as their spacing will be wrong. Quote Link to comment Share on other sites More sharing options...
Mechanical Posted March 11, 2012 Author Share Posted March 11, 2012 Can I ask why you don't just want to make the titleblock the correct size for the paper? I guess if you're bound and determined not to use a titleblock that's the proper size for the paper, you can use the SCALE command to make it a little bit smaller, but I wouldn't advise it, especially if the titleblock contains hash marks around the border as their spacing will be wrong. Just curious about the abilities of autocad. When I saw someone make a titleblock fit they clicked and dragged a box and the title block magically fitted in the layout page extents, but I'm not sure how it was actually done. Quote Link to comment Share on other sites More sharing options...
tmld Posted March 11, 2012 Share Posted March 11, 2012 Yeah, but you'll have to do that each and every layout. Save yourself a huge amount of time and frustration and make a titleblock that fits the printable area of the paper you want to plot to. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 11, 2012 Share Posted March 11, 2012 Perhaps they were using a Either that, or the title block was in first, then they dragged the corner of the viewport to match the titleblock. Actually, I haven't actually inserted a titleblock for years. When I need to add another layout, I either copy one that already exists in the drawing, or I insert the layout from a template drawing. Inserted/coped layouts already contain the paper/plotter setup, the viewport(s) and the titleblock. Quote Link to comment Share on other sites More sharing options...
tmld Posted March 12, 2012 Share Posted March 12, 2012 watched the vid...a dynamic titleblock would be interesting...but it would still vary ever-so-slightly from layout to layout since there are no snap points associated with the dashed printable area line: you could only get so close. [standing on a soapbox, I say] Close is not a standard one should work towards. And since the lower left of printable space is 0,0 why didn't the instructor in the vid make the insertion point 0,0, with the dynamic grip on the opposite corner. It seemed backwards to me. Quote Link to comment Share on other sites More sharing options...
rickh Posted March 12, 2012 Share Posted March 12, 2012 firstly, I agree with others that these should be set so scaling is not needed. If you do want to scale the inaccurate titleblock to be very accurate, then first draw a rectangle the same size as your paper size (ie full bleed pdf sizes for me are -.0625 from the named size. Full bleed 24x36 is an allowable boundary of 23.9375x35.9375. Look at the paper sizes in the print driver properties to see the size of the printable space for each paper size). let's say I draw this rectangle, then insert the titleblock to 0,0. Then select it, SCALE, pick 0,0 as basepoint, select R for reference, pick 0,0 again, then pick the right corner of the titleblock, then pick the right corner of the rectangle. It's as precise as you can get - one rectangle, one scale with reference points. It would be the same idea with a dynamic block (didn't watch the vid but I think I get the jist of it). Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 12, 2012 Share Posted March 12, 2012 Create a template for each size paper you'll be printing to and you'll never have to worry about this ever again. Which is probably something that could have been done in far less time than has been spent posting here. Quote Link to comment Share on other sites More sharing options...
