Results 1 to 6 of 6
    Forum Newbie
    Map 3D 2012
    Mar 2012
    6
    Default Help with COGO where to start
    Good Afternoon,
    I have surveyors descriptions from 2002 or earlier and I am trying to start a parcel layer. Any good suggestions as where to start. I have a layer of Townships, Ranges and Sections from someone who build the existing drawings dating 1996. Since all the existing drawings are based on that, I figure I should stay with it. Any suggestions?
    Many Thanks
    Senior Member
    bill_borec's Computer Details
    Windows 7 - 64 Bit
    Dell XPS
    Intel i7-2600
    8 GB
    AMD Radeon HD 6700
    Dual 24"s
    Civil
    bill_borec's Discipline Details
    Civil PE
    Civil
    Water Resources (Water/Sewer/Storm) Water/Wastewater Treatment Design
    Civil 3D 2013
    Jan 2012
    43.3630N 124.1947W
    166
    I am not sure what your end result will be?
    Are you creating tax-lot drawings? Plat maps? As-builts? New Subdivisions? Right-of-way delineations? ALTA maps? Legal Descriptions? for a Municipality? State Land Dept? Private Owner? Commercial enterprise?
    Can you be more descriptive as to what you have and where you are wanting to be?
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    XP,Visa, Win7
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    TN or KY depends if I'm at work or home.
    584
    Can you post a example of one of those dwgs or a screen shot? Are the existing dwgs in any known coordinate system?
    Murph
    Need a boat or camper for the weekend?
    Forum Newbie
    Map 3D 2012
    Mar 2012
    6
    Default PDF attached???
    Bent with lots 2009_working.pdfFortunately or unfortunately I never had to use screen shots. Bent with lots 2009_working.pdf So I tried attaching a pdf of the area I am working on. The red is the exception right from the deed and it closes nicely but definitely not what I expected.. From what I see the attachment is not readible. I will work on it tomorrow.
    It is not in any coordinate system. Just the drawing from a long time ago. I am thinking, the more I get into this project, I may need to start a whole new drawing or drawings. Not looking forward to it for aligning everything would be job security.
    Many thanks
  5. #5
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    584
    Considering the T/R Sections are from 16 year old data and the survey data is 10 years old I say its pretty close depending on what the final product is for of course. I would start from new dwgs and see if you can locate any know points to start from. If you're not getting current survey data or GPS data you are pretty much doing a guessing game. My rule is if its less than 10 acres then the Township-Range & Sections method is close but no cigar. (my opinion). I would do a few distance & bearings/azimuth check on the dwgs you have and see if they match the surveyor's data you were given.
    Murph
  6. #6
    Forum Newbie
    Map 3D 2012
    Mar 2012
    6
    I truly appreciate hearing what others are doing for it is a guideline as to what I should be accomplishing and whether or not I am going down the right path. When I do the checks the PLSS lines are not lining up the best. One of my main issues is my boss believes the man that drew these drawings was very meticulous so why is the data not aligning up. That drawing I attached was from the same deed, using the same method of drawing the lines, different starting points.
    So what I am thinking for now is to best fit for this little project I am on and when I can formulate a plan/best practice/methods in place for the whole county using cogo using the full potential of AutoCad Map 3D, then start with that.
    Again, I truly appreciate all the comments.
  1. Civil 3D, Cogo points, and PICKADD
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 1st Feb 2012, 10:40 pm
  2. COGO Points not visible in Model tab
    By Bill2X in forum Civil 3D & LDD
    Last Post: 17th Sep 2011, 03:32 am
  3. Cogo Points to Data Collector
    By Teresa in forum AutoCAD General
    Last Post: 24th Aug 2010, 03:25 am
  4. Convert Cogo Points
    By viriato79 in forum Civil 3D & LDD
    Last Post: 5th Dec 2009, 05:35 pm
  5. 3D Polyline from COGO Points?
    By cbriana in forum Civil 3D & LDD
    Last Post: 6th Mar 2009, 04:16 am
