Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2008
    Mar 2012
    4
    Default Help with conversion
    Hello,
    I am developing a 3D project, using Autocad. The project includes a sink (American Standard) and is available only in *.rfa format and I don't have Revit
    Please, is it possible for anyone to convert this file to DWG ?
    Thank you in advance!!
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,233
    I don't think that it is possible to convert it to a 3D object. As far as I know you can only export 2D views to .dwg from Revit.
    Rob
    Forum Newbie
    AutoCAD 2008
    Mar 2012
    4
    Quote Originally Posted by RobDraw View Post
    According with the info I saw, the file can be exported to DWG
    http://forums.autodesk.com/t5/Autode...F/td-p/2766470
    Please?
    Thank you,
    Pat
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,233
    Please look at the .dwgs that were provided. They are in 2D! You requested 3D!
    Rob
  5. #5
    Forum Newbie
    AutoCAD 2008
    Mar 2012
    4
    Thank you for your answer
    I know that the example shows 2D, I just intended to show an example. I remember when I did a Revit Wokshop, we were told this concept, exactly
    http://forums.autodesk.com/t5/forums...ge/true/page/1
  6. #6
    Senior Member Lee Roy's Avatar
    Lee Roy's Computer Details
    Windows 7 Professional 64-bit
    HP Z400
    Intel Xeon W 3565 @ 3.2GHz
    16GB
    ATI FirePro V5900
    OCZ Vertex 4 - 256GB - Sata III - SSD
    Seagate Barracuda 1TB 7200rpm
    Dual - HP Compaq LA2405wg
    Multi-disciplinary
    Lee Roy's Discipline Details
    CAD/BIM Manager
    Multi-disciplinary
    Architectural, Mechanical, Plumbing, Electrical...JOAT
    Revit 2014
    Apr 2011
    Visalia, CA
    417
    Give me a couple minutes.
    -Edit-
    Attached are both an ACIS and a Polymesh version of the supplied .rfa family. The attached files are ACAD 2007 format. If you need anything else, please don't hesitate to ask.
    @RobDraw - Converting Revit files (of any type) is insanely easy. It took me longer to type this response than it took me to convert the supplied .rfa family into both of the attached files.
    Sink-Polymesh.dwg
    Sink-ACIS.dwg
    "The thing about quotes on the internet is that you cannot confirm their validity." - Abraham Lincoln
    I -edit- a lot, sorry.
    The rotary engine is the most efficient way of converting fuel to noise ever invented.
    If my post sounds offensive, but can be meant in a non-offensive manner...I meant the latter.
  7. #7
    Forum Newbie
    AutoCAD 2008
    Mar 2012
    4
    Lee Roy,
    Thank you so much!!!!!!
    Pat
  8. #8
    HP Z400
    16GB
    ATI FirePro V5900
    Multi-disciplinary
    CAD/BIM Manager
    Multi-disciplinary
    Revit 2014
    Apr 2011
    Visalia, CA
    417
    You're welcome.
    ...and welcome to CADTutor! Kick back, relax and stay a while.
  1. PDF to DWG conversion!
    By ED RDNZ in forum AutoCAD General
    Last Post: 6th Jan 2012, 10:49 am
  2. 2D to 3D conversion
    By 3Dsniper in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Nov 2009, 03:19 am
  3. CTB Conversion
    By nihar in forum AutoCAD General
    Last Post: 13th Dec 2008, 09:38 am
  4. PDF to DWG Conversion
    By ReMark in forum Catch All
    Last Post: 21st Feb 2008, 12:46 am
  5. PDF to DWG Conversion
    By dswinty in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jan 2008, 08:27 pm
