Convert assembly file to surface model?
Trisha
Thanks! I have tried to use shrinkwrap, and this seems to work fine onsmaller models without many details. But when I try to convert largerassemblies, inventor crashes and I have to start all over :/
... inventor crashes and I have to start all over
What version of Inventor? Have you installed all Service Packs and Hot Fixes?
I use shrinkwrap often with no problem so I cannot think other that what JD said. Derived part should work (open a new part and click derived part then select the assembly) If all else fails delete the inner workings and leave the shell.
  • 9 years later...
Shrinkwrap will not work on large models (eg. over 3k parts). and shrinkwrap (even as a single solid) can be reversed by saving as STP and and then reopening in inventor.
