Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    Forum Newbie
    AutoCAD 2012
    Feb 2012
    8
    JD mather i have used the same process with a similar design an it worked perfectly, this one however is giving me trouble.
    an i don't have the vanilla autocad but thanks for the tip. ill just use the inventor fusion download. thank you everyone
  2. #12
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,202
    Vanilla AutoCAD is just plain AutoCAD, meaning not a verticle and you should already have Inventor Fusion, maybe IT didn't load it for you.
  3. #13
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    MEP 2013
    Sep 2010
    1,971
    Yes, Fusion is part of a typical 2012 install. You should be able to find it on the Windows Start menu right next to AutoCAD2012, or access it from the Ribbon "Plugins" tab.
  4. #14
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,006
    ...or download here
    http://labs.autodesk.com/utilities/fusion/
    You might check out the Kevin Schnieder free classes here http://au.autodesk.com
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #15
    Full Member
    Landscape
    3D generator's Discipline Details
    generative design consultant
    Landscape
    Extensive experience in sitework detailing using AutoCAD 3d models as the basis for 2d construction documentation. I've been 3d modeling in AutoCAD since the late 90's. Currently transitioning to Inventor.
    Inventor 2012
    Jan 2011
    San Antonio, Texas USA
    35
    Hi Emily,
    I agree with JD Mather, you probably won't have much luck with the Illustrator to AutoCAD workflow. I'd stick with AutoCAD from the start to avoid problems. If you're new to 3d modeling in AutoCAD, I highly recommend JD Mather's tutorials on his website. The link to it is in his signature above. I worked through all of them and it really took my 3d modeling skills to a new level.
    I don't think Inventor Fusion is free but a similar product called Autodesk 123D is free. I've never used it with AutoCAD but it might work for you. It won't have the seamless workflow link that Fusion does though. If Fusion does come with vanilla AutoCAD, you can access it from the command line as well. Just type in EDI at the command line and it should autocomplete to EDITINFUSION if you have it.
    One easy way to ensure tangency in freeform curves is to draw them with the polyline arc option. Each consecutive arc drawn is tangent to the previously drawn arc by default.
  6. #16
    Full Member
    Landscape
    Landscape
    Inventor 2012
    Jan 2011
    35
    I guess I was wrong about Fusion not being free. It will expire in May however.
  7. #17
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,006
    Quote Originally Posted by 3D generator View Post
    I suspect the 2013 version will be available around April 15, not sure if it will be free - but my guess is that it will be free.
  8. #18
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,202
    AFAIK, the Inventor Fusion that comes with AutoCAD 2012 does not expire, the expiration is for the one from Autodesk Labs.
  1. Replies: 17
    Last Post: 12th Mar 2010, 01:33 am
  2. Fillet on a curved edge of a solid
    By varming.dk in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Aug 2008, 11:47 am
  3. Selecting an edge/work point from command line
    By devouring in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2006, 06:24 pm
  4. Edge surface command issues
    By bussolinister in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th May 2006, 06:07 pm
  5. Fillet round edge?
    By 2pac in forum AutoCAD Beginners' Area
    Last Post: 13th Dec 2005, 12:43 pm
