Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Full Member
    Land Desktop 2009
    Sep 2011
    64
    Default Find points pairs with distance tolerance
    Hi lisp masters.I have searched here a lot but could'nt find a lisp which can identify
    almost duplicate points,what i found are duplicate finders.Say i need to know which points are closer by less than 5meters(or any number tolerance). We always receive drawings with many GPS XY coordinates with plenty multiple observations/coordinates which should count as one. We need exact counting.
    Thanks for help.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    I moved this to the AutoLISP, Visual LISP & DCL forum.
    Senior Member ketxu's Avatar
    ketxu's Computer Details
    Sorry, my English not well :(
    AutoCAD 2007
    Sep 2010
    205
    Why don't you post your drawing, and what is the result that you want?
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    <Limited testing> ------->Further testing resulted in FAILURE to give accurate count
    Code:
    (defun c:test  (/ seek fuzz cnt i plst)
    (vl-load-com)
    (defun seek  (pt fz lst / sk lst)
                (setq sk   (ssget "_C"
                                  (polar pt (* pi 0.25) (* fz (sqrt 2)))
                                  (polar pt (* pi 1.25) (* fz (sqrt 2)))
                                  '((0 . "POINT"))))
                (repeat (sslength sk)
                      (setq lst (cons (ssname sk 0) lst))
                      (ssdel (ssname sk 0) sk))
                lst
          (if (and (setq fuzz (getdist "\nEmter Fuzz Value: "))
                   (setq plst nil
                         cnt  0
                         ss   (ssget "_X" (list '(0 . "POINT")(cons 410 (getvar 'Ctab))))))
                (progn (vla-zoomextents (vlax-get-acad-object))
                             (setq en (ssname ss (setq i (1- i))))
                             (if (not (member en plst))
                                   (setq plst (seek (cdr (assoc 10
        (entget en)))
                                                    fuzz
                                                    plst)
                                         cnt  (1+ cnt))(entmod (subst (cons 8 "DuplicatePoints")
        (assoc 8 (entget en)) (entget en))))
                       (princ (strcat "\n"
                                      (itoa cnt)
                                      " Points Found")))
    UPDATED to include place duplicates on Layer "DuplicatePoints"
    :::::Code Failure: :::::
    Last edited by pBe; 17th Mar 2012 at 11:35 am. Reason: Seek again/Select All points on current tab
  5. #5
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,547
    I'd try:
    Code:
    (defun c:findpt (/ fuzz ss bp ps en pp) ; ts is global
      (initget 7)
      (setq fuzz (getdist "\nTolerance Distance:   "))
      (and (princ "\nSelect Base Point:   ")
           (setq ss (ssget '((0 . "POINT"))))
           (= (sslength ss) 1)
           (setq bp (cdr (assoc 10 (entget (ssname ss 0)))))
           (setq ps (ssget "_C" (list (- (car bp) fuzz) (- (cadr bp) fuzz))
                                (list (+ (car bp) fuzz) (+ (cadr bp) fuzz))
                               '((0 . "POINT"))))
           (setq ts (ssadd))
           (while (setq en (ssname ps 0))
                  (setq pp (cdr (assoc 10 (entget en))))
                  (and (not (equal bp pp))
                       (<= (distance bp pp) fuzz)
                       (ssadd en ts))
                  (ssdel en ps))
           (prin1 (sslength ts)))
      (prin1))
    I don't think that the "W" ssget filter will return correct results. -David
    Also, please remember that point values are calculated in 3D
    R12 (Dos) - A2K
  6. #6
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    You may have a point there David...
    I'll have a look-see. tnx
  7. #7
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Here is a 'Divide and Conquer' method:
    Code:
    (defun c:ptcount ( / a b d e f i s x y )
        (setq f  5.0 ;; Tolerance
              d '(8 . "$DUPLICATE-POINTS$") ;; Duplicate Points Layer
        (if (setq s (ssget "_X" '((0 . "POINT") (410 . "Model"))))
                (setq a
                    (vl-sort
                        (repeat (setq i (sslength s))
                            (setq e (entget (ssname s (setq i (1- i))))
                                  a (cons (cons (cdr (assoc 10 e)) e) a)
                       '(lambda ( a b ) (<= (caar a) (caar b)))
                (while (setq x (car a))
                    (setq a (cdr a)
                          b a
                    (while (and (setq y (car b)) (<= (- (caar y) (caar x)) f))
                        (if (<= (distance (car x) (car y)) f)
                                (entmod (subst d (assoc 8 (cdr y)) (cdr y)))
                                (ssdel (cdr (assoc -1 (cdr y))) s)
                        (setq b (cdr b))
                (princ (strcat "\n" (itoa (sslength s)) " Distinct Points to a Tolerance of " (rtos f 2 15)))
    Duplicate points will be placed on a separate layer.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  8. #8
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    Updated the code [post #4]
    Unlike Davids and LMs code that used distance function.I opted to use llist to control selection, that way i dont neet to take into account the Z value. but still osmode whould be set and current zoom will be a factor hee.
  9. #9
    Full Member
    Land Desktop 2009
    Sep 2011
    64
    Tanks good guys pBe,David,LeeMac i'll try them.
    @ketxu here's my prob..
    http://www.4shared.com/photo/tTI3tUks/AcadDup.html
  10. #10
    Full Member
    Land Desktop 2009
    Sep 2011
    64
    @LM.Can we have a prompt for input of tolerance and color of the new layer?
    if not too much of asking .thanks
    Yours WORKED VERY FINE. I just change 'setq f 5' to other number for tolerance
  1. REQ: Place points and cumulative distance (text) on polyline, every X distance
    By enthralled in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Mar 2012, 11:28 am
  2. Measure distance between two intersection points
    By nguyenkaca in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Sep 2011, 12:46 pm
  3. distance between points in lines ?
    By yajis_narif in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2011, 09:20 pm
  4. 2D distance between 3D points
    By Tyke in forum AutoCAD General
    Last Post: 1st Nov 2010, 05:42 pm
  5. distance between points
    By salman in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2009, 04:42 pm
