Results 1 to 7 of 7
    Forum Newbie
    top_cat's Computer Details
    Mac OS X Snow Leopard
    Macbook Pro Unibody 15" i5 2.4
    Whatever comes as standard
    Intel i5 2.4GHz
    4GB
    500GB Internal Drive
    500GB G-Force Drive
    Macbook Pro Monitor
    See details...
    top_cat's Discipline Details
    Theatre
    See details below.
    Theatre Industry... use autocad to design stage sets, stage plots, rigging plots, etc.
    AutoCAD 2011
    Mar 2012
    London, England
    2
    Default Adding Information to Plots
    Hi All. First post, I would normally use the search function (I'm sure some forum police will be along in a bit to tell me so) but I have absolutely no idea what to search for, so I thought I might describe it.
    I want to add a sort of legend / information box to my drawings, in a manner where it can remain constant and in the same place every time I print but I can edit the information therein. I guess that means making up a template, but I'm stuck beyond that.
    Having robbed this picture from the google image search:
    I want to make that table at the top. Maybe add a company logo, the title, scale, author, etc. I'm sure you know the score. But I was hoping I could do it in such a way where I've only got to draw it once and all future drawings I can simply edit the specifics and add it to all drawings, regardless of size or scale.
    Many thanks up front, please go easy on me I normally draw things with a pencil and drawing board and believe me during this learning process there have already been too many times where I'm tempted to go back!
    T.C
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    Its called a title "block" this is a pretty basic drafting 1st step, make it at a scale of 1:1 to suit the size of the plotted paper and put it in paperspace of your layout tab, save it along with all your other std dwg settings & blocks etc than save as a DWT "Template". then you can use it on any project. Each time you copy the layout the "Title goes with it as its a block you can do stuff like sheet numbering.
    Search around 100's of title blocks make sure though no copyright.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,129
    I create Titleblocks in Model Space and make them BLOCKS and Insert Blocks through a Tool Palette or Design Center, but I have all kinds of titleblocks to be used.
    BIGAL's method is the way to go for many.
    AutoCAD 2011 has some at C:\Program Files\Autodesk\AutoCAD 2011\UserDataCache\Template
    Search words in bold.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Draw the title block in modelspace, in a blank drawing, add text, attributes, etc. Save that file as a .dwg file, say TB1.dwg. Now when you start a new drawing go into the Layout Tab and insert the TB1.dwg.
    Create a .dwt (template file) with layer names, linetypes, dimstyles, etc. and use that to start any new drawing. Then insert the title block you want to use in the layout.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    You can use the acadiso.dwt as the basis for your master title block since it is designed to be used for those drawing in metric units. You'll also want to include metric linetypes in your drawing template file not imperial.
  6. #6
    Forum Newbie
    Intel i5 2.4GHz
    4GB
    500GB G-Force Drive
    Macbook Pro Monitor
    See details...
    Theatre
    See details below.
    AutoCAD 2011
    Mar 2012
    London, England
    2
    Nice one people, got that sorted, but slight issue with it now that I can't work out.
    I have created my title block and brought it into the paper space, all good. I have created a viewport within it and got my model into it. All good.
    Now the only thing is that when I add my text to the title block, in paperspace, it appears fine in paperspace but when I go to print it, it all goes sideways and ends up across the model.
    Hope this makes sense, I've googled it but no clues why it's doing that.
    If I get time I'll upload a print screen of it in paperspace and a print screen of it in print preview.
  7. #7
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,129
    Are you using a TrueType font and rotated UCS?
    What plotter?
  1. multiple plots
    By bshaw0777 in forum AutoCAD General
    Last Post: 19th Jan 2010, 09:24 pm
  2. Missing information on plots.
    By www.cmorephotos.co.uk in forum AutoCAD General
    Last Post: 14th Aug 2008, 02:56 pm
  3. Brown Plots Red
    By jphaneuf in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jul 2007, 10:48 am
  4. Why can't I get my plots to work?
    By Beewise in forum AutoCAD Beginners' Area
    Last Post: 7th May 2007, 08:13 am
  5. No more mystery plots
    By daaper in forum AutoCAD General
    Last Post: 5th Jun 2006, 03:27 pm
