Results 1 to 4 of 4
    Senior Member netman's Avatar
    Environmental
    netman's Discipline Details
    Professional Net maker
    Environmental
    I design and fabricate high end research and sampling gears for fishery scientists.
    AutoCAD LT 2012
    Feb 2012
    157
    Default Setting correct scale or Dimensions in a drawing
    IN this drawing, I want the 9.00 to be either 4 ( feet) or 48 (inches).
    How do I set the correct scale in this or any drawing?
    Thank You.
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    Use "Scale" with the (R)eference option...
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Quote Originally Posted by netman View Post
    In AutoCAD, we always want to draw at "full size", so if you want the dimension to read 4 feet (48 inches) you actually make the part 48 inches.
    Assuming you want everything to remain in the same proportions, I would use the SCALE command, with the Reference option.
    Environmental
    Environmental
    AutoCAD LT 2012
    Feb 2012
    157
    Thank you. It was a little confusing to me but that video did the trick.
    Merci Beaucoup again!
    " The absolute, most expensive gear you will ever own is the one that does NOT WORK!"
  1. displaying annotative dimensions in a viewport that not the correct scale?????????
    By MikeP in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2010, 12:52 am
  2. Drawing to the correct dimensions
    By zipper in forum AutoCAD Beginners' Area
    Last Post: 16th Sep 2009, 07:54 pm
  3. Setting scale for drawing
    By Dicky_boy in forum AutoCAD Drawing Management & Output
    Last Post: 6th Nov 2007, 08:26 am
  4. Setting scale of drawing
    By GenSolo in forum AutoCAD General
    Last Post: 30th Sep 2007, 09:39 pm
  5. setting up a drawing to proper scale
    By STEVE M RICE in forum AutoCAD General
    Last Post: 25th Oct 2004, 10:04 pm
