batch plotting/publishing hundreds to pdf...
dlxowhd
What pdf driver are you using?
nevermind.....you beat me.
btw, what was the problem/solution in case others have the same issue?
gutter2d,
look into publish and sheet set manager.
Also, you might want to start a new thread....the first thing people see when they look at this one is that the problem was solved, and probably never make it down to your post.
re plot to pdf and do it for multiple dwgs
Create a script with list of dwgs the Plotpdfa3 is a lisp that plots all layout tabs within a dwg a copy can be found here various versions by searching PDF
open dwg1 (load "plotpdfa3") close n
open dwg2 (load "plotpdfa3") close n
open dwg3 (load "plotpdfa3") close n
open dwg4 (load "plotpdfa3") close n
