Results 1 to 6 of 6
    Full Member
    not specified
    Jan 2006
    hornell ny
    28
    Default Permanent dim and text styles
    Is there a way to permanently save dim and text styles in autocad without going to another drawing template and loading it or putting it in the default drawing template. is there a place add and to store the dimension and text to a dim dex file so it always opens up in autocad.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    Sure, start utilizing the Tool Palettes. What you do is round up all your Dimensions and create a Block of them all. Save the DWG file somewhere in a location that you can always access, then Drag/Drop them into a new Tool Palette. Anytime you open a new drawing, just plop in the block and delete it, and all your DIM styles will carry over with it. Attached is an example of mine....
    **EDIT** Here is some extra info on Tool Palettes in case you are new to them. They are highly versatile and can help in so many ways if you give them a chance.
    http://exchange.autodesk.com/autocad...08800e-10a.htm
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    You can always drag and drop the styles into any drawing you're working in via the Design Center too but working off a tool palette is probably a lot easier.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    For a more automatic approach, I believe you could have acaddoc.lsp perform the suggestions above each time a drawing is opened.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    What version of AutoCAD are you using?
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    A little bit harder you could do a lisp say pick from a dialouge what one you want and create it then in current drawing.
  1. Text Styles
    By SAM_R in forum AutoCAD General
    Last Post: 24th Feb 2009, 09:11 pm
  2. AutoCAD LT text styles/CTB styles not loading....
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 27th Oct 2006, 04:48 pm
  3. Making a lisp a permanent part of the program?
    By New2CADmike in forum AutoCAD Beginners' Area
    Last Post: 24th Sep 2006, 12:15 am
Tags for this Thread
