+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Full Member
    Using
    not specified
    Join Date
    Jan 2006
    Location
    hornell ny
    Posts
    28
    Default Permanent dim and text styles
    Is there a way to permanently save dim and text styles in autocad without going to another drawing template and loading it or putting it in the default drawing template. is there a place add and to store the dimension and text to a dim dex file so it always opens up in autocad.
  2. #2
    Luminous Being StykFacE's Avatar
    Computer Details
    StykFacE's Computer Details
    Operating System:
    Windows 7 Ultimate 64bit
    Computer:
    Dell Precision T3500
    Discipline
    Multi-disciplinary
    StykFacE's Discipline Details
    Occupation
    BIM Manager & Design Specialist
    Discipline
    Multi-disciplinary
    Details
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,495
    Default
    Sure, start utilizing the Tool Palettes. What you do is round up all your Dimensions and create a Block of them all. Save the DWG file somewhere in a location that you can always access, then Drag/Drop them into a new Tool Palette. Anytime you open a new drawing, just plop in the block and delete it, and all your DIM styles will carry over with it. Attached is an example of mine....
    **EDIT** Here is some extra info on Tool Palettes in case you are new to them. They are highly versatile and can help in so many ways if you give them a chance.
    http://exchange.autodesk.com/autocad...08800e-10a.htm
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  3. #3
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,090
    Default
    You can always drag and drop the styles into any drawing you're working in via the Design Center too but working off a tool palette is probably a lot easier.
  4. #4
    Super Member
    Computer Details
    nestly's Computer Details
    Operating System:
    Windows XP Professional (32bit)
    Motherboard:
    Intel DG33FB
    CPU:
    Intel Core2 E2220 @ 2.4GHz
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    250GB WD 7200rpm / 320GB WD 7200rpm
    Secondary Storage:
    500GB WD external USB
    Monitor:
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    For a more automatic approach, I believe you could have acaddoc.lsp perform the suggestions above each time a drawing is opened.
  5. #5
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,124
    Default
    What version of AutoCAD are you using?
  6. #6
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,786
    Default
    A little bit harder you could do a lisp say pick from a dialouge what one you want and create it then in current drawing.
Similar Threads
  1. Text Styles
    By SAM_R in forum AutoCAD General
    Last Post: 24th Feb 2009, 09:11 pm
  2. AutoCAD LT text styles/CTB styles not loading....
    By StykFacE in forum AutoCAD Drawing Management & Output
    Last Post: 27th Oct 2006, 04:48 pm
  3. Making a lisp a permanent part of the program?
    By New2CADmike in forum AutoCAD Beginners' Area
    Last Post: 24th Sep 2006, 12:15 am
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
