Results 1 to 4 of 4
    Forum Newbie
    Map 3D 2010
    Mar 2012
    1
    Default Copyig from one drawing to another drawing?
    How do you copy a non-block item from one drawing to another drawing. With both drawings open, the two methods I've used are the Edit>Copy in drawing 1 and Edit>Paste in drawing or Right mouse button (drop down menu)> Copy in drawing 1 and Right mouse button> Paste in drawing 2. Sometimes one or both methods work and at other times neither works.
    Is there another copy method or am I doing something incorrectly?
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Use copy with base point, either from the Edit menu or if using Ribbon use Home>Clipboard>copy with base point. Then use one of the paste options like paste to original coordinates. In addition I like to use the Clipboard so I have multiple copy clips, I can give them a name and I can see a visual of what they look like before placing them.
    For 2010 you will have to download the clipboard from the autodesk labs.
    http://labs.blogs.com/.services/blog...00d834520f0d69
    e2/search?filter.q=copyclip
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    FjÀrdhundra, Sweden
    5,148
    Hi and welcome to the forums!
    The issue of copy-clip not working sometimes in AutoCAD had been debated over and over both here and at other sites, and I don't think that it has been resolved once and for all. Sometimes a full clipboard is the culprit, but not all the times. I get failed copy-clips more often when I have large drawings going, but it happens at other times too.
    I recommend that you search around and try out different solutions and I hope that you find a solution.
    Good Luck.
    MTJIGSTRING = BAZINGA
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Another technique is with tiled windows - window or crossing window select the geometry you want to copy.
    Then click and hold on one of the lines (not on a grip).
    A special clipboard icon will appear.
    Continue to hold and you can drag (a copy of) the geometry to the second file.
  1. Replies: 3
    Last Post: 14th Sep 2011, 05:48 pm
  2. Replies: 4
    Last Post: 9th Sep 2011, 11:08 pm
  3. Replies: 1
    Last Post: 6th Feb 2011, 02:32 am
  4. Copy AutoCAD Drawing with X-Refences without open drawing
    By samcoozy in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jul 2010, 03:27 pm
  5. Creating a new drawing form an existing drawing -AC2002-
    By Michael in forum AutoCAD Beginners' Area
    Last Post: 16th Apr 2003, 07:41 pm
